This is a discussion thread titled "engine compression testing specs", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-23-2008, 11:15 PM
wirelessf's Avatar
Dealer : Waipahu Toyota
2001 Toyota Tundra,
- Other - 1990 Toyota 4Runner
Last Online: Today 12:18 AM
wirelessf is on a distinguished road.
wirelessf's Photo Albums
Default engine compression testing specs
I recently did an engine compression test and the max pressure was 230psi -/+ 10psi all cylinders. What is the compression specs for the v8 engine? It does not list it on my chiltons book.
01 Toyota Tundra 2UZ-FE
DRL disable mod -TB coolant deicer bypass - rear diff extended breather - poly steering rack bushings -fog light mod - remote ATF filter - Trueflow intake w/ stock filter - SS Autochrome headers
1990 Toyota 4Runner 3VZ-E
Smittybilt Grille Guard - K&N drop in
Old 06-23-2008, 11:52 PM
Senior Contributor
Last Online: Today 12:53 AM
Burger Steak & Eggs will become famous soon enough.
Burger Steak & Eggs's Photo Albums
Default Re: engine compression testing specs
From the 2003 manual:
At 250 rpm,
STD: 192 psi or more
MIN: 142 psi
Difference of pressure between each cylinder = 14 psi or less.
Old 06-24-2008, 06:13 PM
Hi Volt's Avatar
Dealer : Sunrise Toyota - Abbotsford
Last Online: Yesterday 09:55 PM
Hi Volt is on a distinguished road.
Hi Volt's Photo Albums
Was that 10% or 10 psi ? if it was 10 psi then the range is within spec., 10% is kind of a large variance ( 23 psi in your case). The actual max. compression value will depend on a number of things such as engine temp, cranking speed, open or closed throttle, but the variance between cylinders is very important as it can point out a potenial weak cylinder(s). Low overall pressure ( below factory spec) is usually a plainly worn out engine, however a low cylinder or two can point to valve issues, cam issues, head gasket leakage etc.
I tested my 4.7 ( over 210,000 mi.) and the highest was 231 and lowest was 224. The numbers are above the listed factory spec. ( which is good) but more importantly the variance was fairly tight.
If you did have some cylinders bordering on the 10% range, might be an idea to re-run the test and ensure that the compression tester fully seals, even a little leak where it threads in the plug hole will cause a lower reading.
Old 06-24-2008, 08:23 PM
Senior Contributor
Compression tests can be fooled when a poor ring seal keeps a lot of oil around the ring pack. The oil can temporarily seal around the rings well enough at low cranking speeds to artificially inflate the readings (i.e. make the compression test result better than it actually is).
I prefer leakdown tests. In leakdown tests, shop air is blown into a closed combustion chamber, and an air flowmeter measures leakage. This is less likely to be fooled by retained oil because it will tend to push oil back out of the rings for a more realistic measurement of leakage.
Old 06-24-2008, 08:32 PM
wirelessf's Avatar
2001 Toyota Tundra,
I relooked over my test results and all are within specs. Lowest was 225psi.
Bookmarks
