This is a discussion thread titled "stuck on header install", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 07-08-2008, 09:15 PM
wirelessf's Avatar
Dealer : Waipahu Toyota
2001 Toyota Tundra,
- Other - 1990 Toyota 4Runner
Last Online: Today 12:18 AM
wirelessf is on a distinguished road.
wirelessf's Photo Albums
Default stuck on header install
What did you guys use to remove the bottom exhaust manifold nuts? I'm stuck at this part and almost have to resort to removing the engine mount for this. I do have a bunch of extensions and u-joints, but i dunno the perfect combination to reach those two bolts without removing the engine mounts.
01 Toyota Tundra 2UZ-FE
DRL disable mod -TB coolant deicer bypass - rear diff extended breather - poly steering rack bushings -fog light mod - remote ATF filter - Trueflow intake w/ stock filter - SS Autochrome headers
1990 Toyota 4Runner 3VZ-E
Smittybilt Grille Guard - K&N drop in
Old 07-08-2008, 09:48 PM
Dealer : Lancaster Toyota
Last Online: 10-10-2008 06:21 AM
boosted3g is on a distinguished road.
boosted3g's Photo Albums
Default Re: stuck on header install
Do yourself a favor and remove the mounts. It only takes a few minutes per side. It will also make it a lot easier to fish the headers in. It is a lot easier to slide the headers in from the back rather than the front. the passenger side there is a lot of room but the drivers side does get tight because of the steering shaft. I just did a set of JBA's on my 01 2 weekends ago and didnt have too bad of a time. Once the mounts are out and the engine is supported on a jack you can actually move it back and forth a few inches to help with clearance.
Old 07-09-2008, 12:43 AM
wirelessf's Avatar
2001 Toyota Tundra,
I decided to remove the mounts one side at a time while doing each header. Gives me plenty room!
Another question, did you reuse the collector gaskets that goes between the header and cat and the y pipe gaskets?
Old 07-09-2008, 09:18 PM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Eddie is on a distinguished road.
Eddie's Photo Albums
I bought new ones.
Bookmarks
