Old 04-02-2003, 10:47 AM
sbl's Avatar
sbl sbl is offline
Dealer : Heartland Toyota - Williams Lake
sbl is on a distinguished road.
sbl's Photo Albums
Default How do you change power steering fluid?
I have never changed my power steering fluid and would like to replace it with Amsoil. Is this easy? Any help would be appreciated.
sbl
Old 04-02-2003, 12:17 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
You can suck it out of the reservoir with anything that'll work...but don't let your Mrs. see you using her turkey baster. Or, disconnect the lower hose and drain it into a catch container.
Refill with your choice of ATF. Drive a while so it circulates, and do the whole process again, and once more if you wish. You can probably do three changes with a quart of ATF.
Ken
Old 04-02-2003, 02:32 PM
sbl's Avatar
sbl sbl is offline
sbl's Photo Albums
Smile
sbl
Old 04-02-2003, 09:59 PM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 11-14-2009 08:18 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
When I did mine I went and bought one of those cheapie siphon pumps at AutoZone for $2.99 and 1 quart of Mobil 1 ATF. Siphoned old stuff out of reservior, filled with Mobil 1 ATF, drove around, siphoned and filled again, done. Just check the level the next day after driving to make sure its topped off properly.
Ken is right, I think I still had a little ATF left after 2 fills.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
