Usually the front line comes out of the pump, and the rear line is the return.
I'll try and remember to check the service manual when I get home, it will probably say...
The time-tested method of figuring out which is which: Disconnect both lines, rubber band a couple of small plastic bags over the ends. Blip the starter a few short times. If it starts, kill it right away. Look at the bags. One will be bulging with fluid, the other sucked dry.
