This is a discussion thread titled "no BS I need some more torque", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-18-2003, 08:36 AM
Last Online: 05-21-2004 04:56 PM
bigdog is on a distinguished road.
bigdog's Photo Albums
Unhappy no BS I need some more torque
We just dragged home our new 23 foot Chaparral deck boat and my 2002 4x4 access is not all that happy about towing it. We live in Colorado and drive some big hills to go boating, plus the power loss to altitude.
What is the bottom line about getting a few more foot pounds out of the 4.7 at a reasonable cost? No supercharge in my future as the boat is already more than I should be spending. Am I gonna have to go with an American truck? Argggg!
Old 04-18-2003, 12:30 PM
Last Online: 10-01-2003 02:51 AM
indecline is on a distinguished road.
indecline's Photo Albums
How much does the boat weigh?
No BS? You're not going to get any real significant power gains without some kind of forced induction = supercharger. Your Tundra was pretty much designed to produce the amount of torque it does (DOHC engines are traditionally not high-torque engines) the way it is built from the factory.
I've got news for you. If you can't afford a $4000 supercharger, how do you expect to afford an F250? Or any of the American trucks with a big block/diesel high torque engine? Its certainly going to be a lot more expensive than what you paid for your truck - even with the added price of the s/c - anything around the same price of the Tundra is going to have less torque and a weaker engine - unless you get something used.
good luck,
jason
Old 04-18-2003, 09:41 PM
Dealer : Toyota of Riverside
Last Online: 01-08-2008 02:29 PM
Johnnyrcp is on a distinguished road.
Johnnyrcp's Photo Albums
Default Weight
Buddy of mine did a spacer on the intake runner and oversized the exaust to 3.25" with hiflow muffs... said it was 15% improvement from Stock ... Also added airbags to rear for leveling !
Good luck
good luck,
jason
Old 04-19-2003, 12:47 AM
Last Online: 08-01-2005 10:16 PM
blderman is on a distinguished road.
blderman's Photo Albums
Default Re: Weight
Good luck
It may be an "advertised" 15 % increase but I can assure you that the setup described above will help your top end but your low end will suffer and that is where you need torque for towing. That exhaust system would need an x-pipe or similiar in order to help the low end. About the spacer are you talking about a throttle body spacer or did your friend make a custom spacer for the runner plenum?
Without going to a S/C the only other options maybe tuned headers and possibly some porting and polishing of the intake runners but neither of these will make a substantail difference. You can bet though as said already than any other truck in this class isn't going to make any better power than the tundra. If you're going to spend the cash get a S/C.
Jason
Old 04-19-2003, 12:55 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 01-02-2009 07:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
If a 1/2 Ton with more torque would be heavy enough, you might think about some options on an F-150 with a 5.4. They've got a lot more low end torque than a Tundra. You used to be able to get them with 4.10's. That would help too. The price should be about the same as a Tundra, maybe a bit less.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 04-19-2003, 06:55 AM
TRDKEAU's Avatar
Dealer : Carson Toyota Scion
2006 Toyota 4Runner
Last Online: 07-24-2008 12:36 PM
TRDKEAU is on a distinguished road.
TRDKEAU's Photo Albums
trade it in..a dakota r/t will pull better. Or get the nissan Titan 5.3 V8.
Old 04-19-2003, 09:15 AM
Dealer : Panama City Toyota Scion
Last Online: 08-13-2007 07:39 PM
Jimbo is on a distinguished road.
Jimbo's Photo Albums
Default Change in axle ratio
A change in axle ratio is a permanent increase in torque applied to the ground - for a given ground speed - which is what towing needs. Maybe 15% higher gearing is what you need. Yes, in a 4x4 truck this requires two sets of gears to be changed, but that is the cost of 4 wheel drive.
Can you accept a 15% decrease in miles per gallon, to go along with the re-gearing? Re-gearing in this case is to make use of the higher torque the engine makes in the "higher than stock" cruising rpm (compared to stock gearing).
The Tundra V-8 has a torque peak at somewhere between 3,000 and 4,000 RPM. Until you chassis dyno your truck, you won't know the peak torque RPM (and equivalent ground speed for each transmission gear) for your truck. Re-gearing the axle ratios based on the dyno results should work well, if your wallet can handle it.
Good Luck
Old 04-19-2003, 11:13 AM
ricqik's Avatar
Last Online: 01-04-2009 08:03 PM
ricqik is on a distinguished road.
ricqik's Photo Albums
LOL
02 Dak R/T = 2000lbs max tow
Stuffs:
JBA Headers, Costum Exhaust, ASP U/D Pulley, Centric Crossdrilled & Slotted Fr Rotors, LSD, IS Kit, Manik SS Steps, HID Headlights & Fogs, Pacer Tailgate LED Light Bar, Blacked Out Headlight & corners, LED tail lights
Toys:
04 Skeeter ZX250 w/300 Vmax HPDI (79.35gps so far)
05 Polaris Sportsman 700TWIN EFI (rarely ride)
Old 04-19-2003, 02:30 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
A change in axle ratio is the only thing that will work for you with this present truck.
Forget all the talk about torque. It's not meaningful. What you and everybody needs is horsepower at the rpms they're working the engine. Lower gear ratios make the engine spin faster and produce more hp at the same mph, at the expense of fuel consumption. The horsepower curve is what you need to consider. Any add-ons, K&N stuff, etc., need to be carefully evaluated to see if they give you any more hp at the rpms you really use, not more hp (if any) at peak rpm. If S&S ever gets going on the headers, they've been requested to increase the hp in the 2000-4000 rpm range, not at peak.
Right now, what can you do?
1) Never tow that boat in Overdrive.
2) Install an additional transmission cooler and synthetic ATF.
3) Run up to, say, 4500 rpm by manual downshifting...minimize shifts to minimize transmission heat and wear.
4) Downshift early when driving down hill, and come down in 2nd, or 1st if need be.
5) Your boat trailer has brakes, yes? Trailer brakes are essential anytime the total weight is above the truck's GVWR of 6k#.
6) Take your time.
7) Regear the differentials.
Ken
Old 04-19-2003, 05:00 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
Last Online: 03-27-2008 09:05 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
bigdog,
If you won't consider supercharger but think a new American truck is the answer than how much do you think that would cost you to get a new truck in comparison to the supercharger?
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
Old 04-19-2003, 07:57 PM
fastmhz's Avatar
Dealer : Elmore Toyota Scion
2000 Toyota Tundra,
2005 Toyota 4Runner
Last Online: 01-02-2009 06:14 PM
fastmhz is on a distinguished road.
Send a message via AIM to fastmhz fastmhz's Photo Albums
A set of headers should help
Old 04-19-2003, 08:48 PM
Originally posted by v8Toilet
bigdog,
Good point, except I would hit the rather soft market of full size sport Utes. They are giving away Tahoe's in Texas. Friend just bought one on ebay, $9,200 for a 98 with 80k miles loaded. Perfect and loaded too.
On the other hand, I just compared a Tahoe (98) and my truck pulling my boat (4k pounds plus big ol' trailer and 50 gallons of fuel) and there was almost no difference except on the extreme bottom end.
I did your pulse mod and it really did feel like it pulled better from a stand still. I am thinking the spintech is for me, as well as perhaps a set of headers. Anyone try the JBA's from this site? AEM said they will an intake kit by end of the month, and they post dyno numbers, just like v8toilet!!
Old 04-20-2003, 06:49 AM
TRDKEAU's Avatar
2006 Toyota 4Runner
you like that one huh ricqik!!!
Old 04-20-2003, 10:41 AM
ricqik's Avatar
Oh I forgot, it's a dakota, it can do anything. Our tundra's can't pull that, it's too heavy for a toyota.
Stuffs:
Toys:
Old 04-20-2003, 11:58 AM
You guys mention a gear change, who make a lower Tundra gear right now ?
Bookmarks
