Old 04-21-2003, 06:10 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
Last Online: 08-20-2009 06:58 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
Default Tundra rich air fuel ratio/ response from New England Dyno
Just a recap I put my truck on a dynamometer with exhaust gas analyzing to run some tests of before and after with exhaust and intake modifications. The Exhaust gas analyzer used was a wide ban 02 sensor type that measured the oxygen content in the exhaust stream and a computer calculated the air fuel ratio based on this information. I started a thread called Reason why the I-force v8 doesn’t respond very well to engine modifications. stating that the i-force V8 doesn’t respond to engine modifications because the air fuel ratio will go rich when you modify it. Some TS members argued that this was due to the fact that the catalytic converters skew the readings after the cats and give a wide band 02 sensor type exhaust gas analyzer false readings. I then argued that other vehicles there had similar emissions equipment and that if that were so than they too would show similar results on the exhaust gas analyzer.
I eventually talked the dyno owner operator (Dean) via e-mail and provided him with information I was getting from TS and he eventually talked to the dynojet manufacturer about this situation. Again I explained to them about how the catalytic converters could effect the after cat emissions when using a wide band 02 sensor and also explained to them about what I learned from TS members in this thread.
Dean wrote,
John,
I will have to forward this to Dynojet to see what they say. We have dynoed 100's of domestic and foreign cars including numerous with OBD2 as well as ULEV vehicles and have never had an issue. But in this day and age anything is possible with a particular model.
We have tested many cars by sampling with the wideband at the header and at the exhaust and readings are typically identical unless there is a hole somewhere in the exhaust system.
The majority of the top aftermarket tuners in the US all use the wideband O2 with no issues - I would not be able to justify a gas analyzer for only the Tundra as we have never had issues with any other Toyota model or any other model for that matter.
I will let you know how they respond as I dont have an answer for you.
Thanks,
Dean
www.nedyno.com
When I asked Dean if it is typical for him to see black smoke coming form the exhaust this was his response.
John,
Sorry for the delay getting back to you. If its running rich, and you have a good cat and mufflers you usually wont see a big black cloud. The wideband only goes to 10:1 on the low end.
Hope this helps!
Dean
www.nedyno.com
I just received a response from Dean stating this,
Here is the response I received from Dynojet:
Dean,
From all of the testing we (and many of our customers) have performed, measuring pre and post cat yield the same air/fuel ratio measurements. I believe the best answer for this is that while performing a typical roll-on on the dynamometer, the converters are overwhelmed to a large degree and cannot do their job. Converters work well under light load and especially at idle and I believe that is where emissions are focusing.
I really don’t have any real tangible scientific data or graphs for you but I hope this helps. I would recommend trying it yourself pre and post cat and see for your self. We had one customer who was adamant about it and we told him to perform his own testing and sure enough he called back and said there was no difference other than a slight delay in response from testing at the tailpipe versus the exhaust bung.
Let me know if you have any other questions.
I would like to get some more commentary from any TS members who are knowledgeable on this subject. In my opinion I think the only way to back up the validity of the results from the wide band 02 sensor readings is to compare them with the results from an exhaust gas analyzer that reads carbon monoxide, Oxygen, hydrocarbons, and carbon dioxide.
If the engine was actually running rich the carbon dioxide would go sky high and even the most efficient catalytic converters wouldn’t help unless there were an air pump to add additional oxygen to the catalytic converters and there isn’t an air pump on the Tundra. If there isn’t enough oxygen (02) present for the hydrocarbons (HC) to have complete combustion than instead of one carbon atom combing with two oxygen atoms and getting carbon dioxide (CO2) you get only one oxygen atom combining with one carbon atom and you get carbon monoxide (CO or CO1). We won’t worry about N02 emissions OK although they would indicate a high combustion temperature and an overly rich mixture would cool the combustion chambers.
Sampling in front of the catalytic converters could and would be a viable test but I would have to modify the exhaust by welding a bung in it and fitting it with an expensive wide band 02 sensor. If I remove the existing 02 sensors I would be removing the sensors that the computer relies on for reading the exhaust gas oxygen content and I’m afraid I would ruin something or skew the results of the tests. I could just put a DVM on the existing 02 sensor but it would only read the maximum voltage of .9 volts letting me know that the exhaust is rich but not by how much. When a rich exhaust goes beyond the range of the 02 sensor (and it will) than the maximum reading from the 02 sensor will read the same .9 volts regardless of how rich the air fuel mixture is.
I just need to find someone who has a machine like this that I could use for a reasonable price. I would like to be proven wrong with some kind of test as I have mensioned above. I don’t want to just assume anything!
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
Old 04-21-2003, 06:32 PM
v8Toilet's Avatar
Here is what my air fuel ratio looked like stock vs. using the Spintech muffler and I let the computer acclimate to the Spintech muffler for ~150-200 miles. Right after I put the stock exhaust back on and drove for about 10 miles the air fuel ratio went leaner.
Spintech air fuel vs. stock
Vanityplates has TRD headers and a dual exhaust and his looked better but he also drove his truck for many more miles with his modifications than I did. As soon as he removed the air filter though his air fuel ratio went super rich and he lost power.
Vanityplates air fuel ratio
Here is what every other truck looked like there with similar OBD2 emissions and catalytic converters.
Typical American truck
You think the v6 air fuel ratio would read the same
stock exhaust
TRD LSD
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Old 04-22-2003, 12:23 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 11-17-2009 03:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
Don't know the answer, but did want to point out that you should have your atoms (not molecules) of Carbon and Oxygen combining to form the molecules of your newly formed compound CO or CO2. Did you actually have black smoke rolling out when you were on the dyno? You might PM Yellbird to see if his smoked; I know the dyno operator told him it was running really rich.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 04-23-2003, 07:40 PM
Dealer : Charles Maund Toyota
2003 Toyota Tundra
Last Online: 03-01-2008 04:34 PM
Hollywood03 is on a distinguished road.
Hollywood03's Photo Albums
Well, from some experience, mostly in domestics, this is what I can say.
The Cats have little in nothing to do with the O2 readings at the tail pipe. If you wanted you could, but some sort of bung in the exhaust, the wideband would not have to be welded just supported for the pull. Then you could test it for sure. But from experience I can tell you it does not matter.
Second I do agree that the computer richens the mixture when the mods are done, and it re-learns what is going on and returns to the factory Fuel and Air ratios. The Ford computers do the same thing. However has anyone tried to use an AFC or some sort of fuel management to cure this. With the AFC you could tune the truck with the MAF, lean it out, and gain the performance. I was going to do this for better gas milelage. 12:1 is too rich for the street NA motors. I think this is some of the problem with the S/C guys running 12 psi of boost and not making but 80 more hp. Theoretically if you double the pressure in the motor, you double the power and 12 psi is almost 2 atmospheres. Of course it is minus parasitic losses, but non the less it should be more than a 80hp gain.
Of course I just bought my Tundra and have no data, but this is mostly Theory and Fact. If anybody has insight please let me know.
Jason
Old 04-24-2003, 09:50 PM
v8Toilet's Avatar
Jason
Wouldn’t the OBD 2 computer relearn the changes made by such a piggy back computer and detune that as well?
stock exhaust
TRD LSD
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Old 06-09-2006, 02:22 AM
Justang's Avatar
Dealer : South Coast Toyota Scion
2006 Toyota Tundra,
2002 Toyota Camry,
- Other - Mazda6
Last Online: 06-30-2009 12:37 AM
Justang is on a distinguished road.
Justang's Photo Albums
Default Re: Tundra rich air fuel ratio/ response from New England Dyno
Jason
12psi is not almost 2 atmosphere's. 14.7psi is one atmosphere.
Is it possible to put an adjustable fuel pressure regulator on these engines to gain a desireable a/f ratio? 12.5 to 13 would be nice.
2007 Ford F250 SuperDuty Diesel | DSG | 4x4 |
07 Ducati Monster S2R 1000
98 Yamaha YZ250
Had a Tundy once upon a time...
Old 06-09-2006, 07:18 PM
mmarlatt's Avatar
Dealer : Toyota of Vacaville
2003 Toyota Tundra
Last Online: 03-23-2009 12:43 AM
mmarlatt is on a distinguished road.
Send a message via AIM to mmarlatt mmarlatt's Photo Albums
And since nearly all engines operate within the atmosphere 14.7 + 12 psi is an aboslute pressure of almost 2 atmosphere
2003 Stratosphere Mica SR5 Access Cab
Shocks: Bilstein 5100 coilovers and 5100s in the rear.
Wheels: Toyo Open Country A/T 275/70/16s on MB Blitz rims
Old 06-10-2006, 11:01 PM
Justang's Avatar
2006 Toyota Tundra,
2002 Toyota Camry,
- Other - Mazda6
That is technically true. So I was technically wrong.
But, if we want to be technical, why do the boost gauges read 0psi, when it should read 14.7 (at sea level)?
98 Yamaha YZ250
Old 06-11-2006, 12:40 AM
mmarlatt's Avatar
2003 Toyota Tundra
Cause the boost gauge is reading the different in pressure between the outside (atmosphere) and the inside of the gauge (what it is connected to). This is often called psig; where the 'g' stands for gauge. To get the absolute pressure (psia) you have to add the atmospheric pressure to the psig.
