Thanks to everyone that posted about how to fix an P0051 error code for the front passenger side oxygen sensor. Thanks to everyone else, my experience went very well today. I would like to add the following.
First, as others have said in this post and others, getting a special socket for this job is a must. I found one at Harbor Freight dirt cheap but ended up going with this OEM 27110 set on
amazon instead for $17.24. I did not know if I would need more than just the socket but I wanted to be prepared for anything. As it turns out, I only used the socket.
Amazon.com: OEM 27110 Oxygen Sensor Socket: Automotive
Also, I bought an Equus 3030 engine code reader for $59.99. This was optional since in most states Advanced Auto will read your code for free but I figured with all the money I was saving by not having this problem fixed at the dealership, I could splurge and buy another tool. I love tools. Before I started the project, I used this to confirm that I only had one bad sensor. It had been awhile since I had Advanced Auto read my code so I wondered if a second one had gone bad. So far, only the front passenger side ox sensor has gone bad. From what I read on the Internet, most of these low priced engine code readers have the same features. I picked this one because the display was bigger than the alternatives.
Lastly, I bought the new oxygen sensor. I called the dealership and they wanted around $157 if I remember correctly. Next, I checked Rock Auto. I found an exact replacement Denso (OEM not universal fit) for $62.01 after my discount including shipping. I discovered on
Coupon codes and discounts for 30,000 online stores! RetailMeNot.com, a promo code that I used for an additional discount in order to get the price that low.
Finally, it was time to actually get under the truck. After 94,000 miles and numerous Michigan winters on my '03, I was expecting a long day. Thankfully, I was wrong. I tried to take plenty of pictures as I went to help out the next person to read this thread. Here's an overview of the sensor. I found it was often easiest to get to it with my body parallel to the body of the truck with my feet under the front bumper.
Below is a closeup of the threaded portion of the sensor. Most of my time was spent removing this. The rust had seized it up. Unfortunately, I had not sprayed it with Liquid Wrench prior to today. You will need some exensions for your ratchet in order to get at it. I did not have a really long extension so I combined two 6" extensions. It was not budging so I encouraged it a little with a cheater bar. I tried to be patient because I had read on the Internet about people stripping the threads. Eventually, it broke loose.
Here's the threaded portion after removal.
As many other people have noted, getting the plug end removed can be a real pain. First, I tried the screwdriver method to try to unclip it. This was going very badly. I was concerned that I was going to break the part that remains on the truck for the next sensor. Then, I reread this thread again. I tried to use my middle finger to reach up on the top side of the plug, release the catch, and then use my remaining fingers on the same hand to remove the plug. It is only possible to get one hand up there at a time. In order to do this, I had to work blindly with my feet under the front bumper. Amazingly, despite my big hands, this worked very easily. Here's a closeup of the plug end of the sensor.
And here it is again after the plug was removed.
Installing the new one was easy. The Denso replacement came packaged with some anti-seize. There was plenty left over for future projects too. Here's the finished install.
Lastly, I used my new engine code reader to erase the error. I put the truck back down on the ground, started it up, and for the first time in months there was no engine light on.
Thanks again everyone for making this project go so well.
