This is a discussion thread titled "erratic idle", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-05-2003, 08:24 PM
Last Online: 11-14-2006 03:12 PM
davo55 is on a distinguished road.
davo55's Photo Albums
Question erratic idle
2001 Tundra 4x4 V8 automatic trans. Concern: When and only when I have the interior fan running and I'm waiting at a stop light in gear, I hear a low click from behind the dash by the glove box and the engine idle increases enough so that I have to apply a bit more pressure on the brake to keep still. Then, a minute or less later, the same click happens and then it idles back down to normal. The air conditioning is not on. Any ideas? worth taking in to get looked at on Warranty?
thanks
Dave
Old 05-05-2003, 10:00 PM
Dealer : Panama City Toyota Scion
Last Online: 08-13-2007 07:39 PM
Jimbo is on a distinguished road.
Jimbo's Photo Albums
Unhappy
The engine management computer is raising the idle on your engine, that much is certain. The idle should not be raised by the computer when fan/climate control system is off.
With your comment that AC is off, perhaps you have selected defrost, in that case AC compressor is usually turned on - even when you don't push the AC button.
Maybe your AC on light is broken, or the button/switch for AC is stuck ON even with it appearing to be OFF.
Jimbo
Old 05-05-2003, 10:20 PM
Last Online: 01-27-2005 10:47 PM
tonyp is on a distinguished road.
tonyp's Photo Albums
Default re:erratic idle
If the climate control switch is in defrost or floor/defrost, the a/c compressor WILL run. That will cause and increase in enginr idle speed and you will have to press harder on the brake. Is your climate control selector switch in either one of thede positions???
Old 05-05-2003, 11:38 PM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 01-01-2009 05:17 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
Classic symptons of the A/C compressor kicking on/off. Odds are you have the selector in one of the settings noted below. If so its normal. You will get used to it and compensate for it.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 05-06-2003, 06:53 PM
Default Re: re:erratic idle
Why, yes it is as a matter of fact. That pretty well answers my question.
thanks
Dave
Bookmarks
