Originally posted by santacruzc156
just a few days ago my steering wheel started to squeak when I turned it. I doesn't whine like power steering, it squeaks like vinyl rubbing on something. it doesn't start whining until after I've been driving my truck for about 10 minutes or so. I have 25,000 miles on my truck right now.
It's likely a bad "clock spring" -- the spiral-wound cable assembly that connects the airbag, cruise switch and horn button to the steering column wiring.
If you can demonstrate the noise to the dealer they should cover it under warranty. Also, because it is part of the airbag system if should be covered for the same term as the "restraint system warranty" (which I don't remember off-hand, but I'm pretty sure it's longer than the 3/36 bumper-to-bumper).
