This is a discussion thread titled "Jiffy Lube Trans. service", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Not sure if Jiffy Lube will refill you with Mobil 1. They are a subsidary of Shell and use mostly Pennzoil & Quaker State products (also subsidaries of Shell)
__________________ ~Glenn~
Forum Rules
I call them Jiffy Screwed. My friend had them change out his differential fluid and add the 4 oz. tube friction modifier (for limited slip diff) he provided.
Well on half way to work the next day the diff started to howl and make awful noises. He looked under the car and saw the funky color of solid friction modifier around the pinion seal. He limped the vehicle to work and put it on a lift and found they only put the 4 oz. tube of friction modifier and did not fill the diff with gear oil. The pinion bearing was shot and as a result it roached out the pinion seal. I would never let these clowns touch my vehicle much less use a P.O.S. fram filter.
Certified Technicians -- ya right!
Do yourself a favor stay away from Jiffy Screwed especially for something not routine as flushing tranny fluid.
BTW Jiffy Screwed wasn't coopertive in the matter. Because of the time and resources it would have taken him to pursue the matter he just let it go and tells his story whenever he can. I witnessed this first hand so this was a nice opportunity to share this.
i'd suggest finding a good independent mechanic. those franchised drive-thru shops are just like greasy fast-food joints. they're fast, but they're probably not good for ya!
