Originally posted by rotts4u
I usually do my own oil changes and greasing etc but no matter how hard I try I can not get the front Drive shaft to take any grease. The fitting is so tight or something and it just squirts out.
I have tried two different guns and they both do it. I have also rotated the shaft to various angles etc.
What is the secret to this? I have 10k miles and dont want to ruin anything !!
HELP
Don
Get a needle for your greese gun and you'll be able to grease it fine. You can try other fittings, but this is easier (as long as you don't crush the fragile tip)
http://www.tools-plus.com/lnc82784.html
I kind of like this type of needle better if your going to be pulling it off and putting it on a lot.
http://www.tireservicecentral.com/Pr...n_tools_13.htm
To be honest. Even if you *never* greased that front shaft it would probably last the life of the vehicle and then some.
Most people don't use the front shaft enough to really need much grease.
Oh, you might like to get some grease fitting caps. If you use this needle or something like it and put caps on the fittings to keep it clean you'll find greasing the shaft fittings are a breeze.
Alan
