This is a discussion thread titled "Rough Idle", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-13-2003, 07:55 PM
Dealer : Cobb County Toyota Scion
Last Online: 11-30-2008 06:35 AM
hogrider21 is on a distinguished road.
hogrider21's Photo Albums
Default Rough Idle
Hey All,
I have a 2001 Tundra TRD 4x2. Only mod is a K&N drop in. I recently changed to the spark plugs that I got from the dealer. They said that the plugs were gapped already. At times when in gear and sitting at a stoplight, I get a little rough idle. I'm going to pull the plugs and check the gap again. But I was wondering if anyone has experienced this same problem? I also cleaned the throttle body about a month before I installed the plugs. I also run 89 octane. Any ideas besides the the gap in the plugs?
Thanks.
Old 05-13-2003, 08:58 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
Last Online: 03-27-2008 09:05 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
Loose connections on air cleaner or throttle body hose. Oil from the K&N filter contaminating the mass air flow sensor causing rough idle and loss of power.
If the engine was misfiring the Check engine light would illuminate!
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
Old 05-14-2003, 11:03 AM
Thanks. I will check those connections.
Old 05-15-2003, 07:59 PM
Last Online: 12-24-2007 11:59 AM
Tundradad is on a distinguished road.
Tundradad's Photo Albums
Where is your tach needle when it is at rough idle? If it is between the two marks, that is where it is supposed to idle,(smooth) if it is below the lowest mark it will idle rough and the only way I know how to bring it up is bring it to the dealer. Does it idle smooth at a faster idle??
Old 05-15-2003, 10:56 PM
It's actually a little above the last 2 marks. I had a hose that I thought was a little loose and I clamped it down. I also cleaned my throttle body. It appears to be fine. This weekend I will check the gaps on the spark plugs just incase they did not gap them correctly.
Thanks for the reply.
Bookmarks
