Old 11-21-2008, 08:04 PM
Dealer : Lia Toyota
Last Online: 09-06-2009 08:35 PM
polishkid413 is on a distinguished road.
polishkid413's Photo Albums
Default 2000 4x4 Differential Problem
I took the truck to AAMCO today because it was clunking when I would take a corner. They told me that my rear differential was shot and I needed to have it rebuilt or replaced. They offered to install a new one for me or find an entire used axle at a junk yard. They wanted a little more than I have to spend for the job, so I was wondering if I just installed a new third member if that would solve my problem, or is the differential not part of the third member?
Old 11-27-2008, 11:29 PM
ctw41's Avatar
Dealer : Lighthouse Toyota Scion
2000 Toyota Tundra Limited 4WD,
- Other - 07 Jayco Motorcoach
Last Online: 11-14-2009 10:03 PM
ctw41 is on a distinguished road.
ctw41's Photo Albums
Default Re: 2000 4x4 Differential Problem
The Ring and Pinion along with the spider gears is in the center part of your rear axle along with supporting bearings. You have the axles going out from there supported by bearings with seals at the ends. The "third member" is usually referred to as the center part I mentioned. What goes bad are the bearings and usually teeth get stripped off the spider gears, ring gear or pinion gear or all of the above.
I would get a second opinion to be sure. My 2000 tundra 4wd has 114000 miles and still holding up fine. In most cases as long as the seals stay intact and your fluid is the right level and clean you can go hundreds of thousands aof miles without a problem
