This is a discussion thread titled "R-134a additive.", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-18-2003, 10:20 PM
fly fly is offline
Dealer : Toyota of Longview
Last Online: 01-06-2009 11:58 PM
fly is on a distinguished road.
fly's Photo Albums
Default R-134a additive.
Has anyone tried this stuff?. I have tried other additives in the past and was not impressed. I am thinking of getting a can to test in my wifes car. I think this stuff might really work, as it is associated with NASA and the DOD.
Seriously,this is something you can easily test with a thermometer.
Old 05-18-2003, 11:27 PM
Dealer : Russel Toyota
Last Online: 03-12-2006 06:51 PM
Stooge is on a distinguished road.
Stooge's Photo Albums
Fly
Like all additives, most just drain your wallet and do nothing. This additive probably has a good amount of propane. See if the can says its "flammable" - a good sign. Propane can help the system but is flammable and is hard on the seals and moving parts. If your AC system is not performing properly, do the following:
Clean the condenser (heat exchanger in front of the radiator
Make sure the evaporator in the dash is not caked with leaves and dirt (may take some disassembly)
Make sure the heater water valve on the firewall is all the way shut when in the COLD position
If still not working right (AC air should be at least 20 degrees colder than ambient air temp), check the charge.
Ensure the compressor runs continuously (cycling CAN indicate a low charge)
If the charge is low, there's a leak - find and fix
Once fixed, have the system evacuated using a vacuum pump for a couple hours - important
Recharge with oil (proper amount)
Use a charging bottle to refill with refrigerant (amount listed on nameplate under hood)
Happy Hunting
Mike
Old 05-19-2003, 07:52 AM
tundrawes's Avatar
Dealer : Metroplex Toyota
2002 Toyota Tundra
Last Online: 01-07-2009 07:15 PM
tundrawes is on a distinguished road.
Send a message via AIM to tundrawes tundrawes's Photo Albums
I noticed you mentioned the following
"Ensure the compressor runs continuously (cycling CAN indicate a low charge)"
Mine clicks on and off (I noticed because the rpms move up and down every few minutes when im at a stop), is this a problem?
Old 05-19-2003, 07:54 AM
Depends on how cold or hot it is outside. You can buy a cheap, low side guage at the autoparts store to check the charge. Instructions included!!
Old 05-19-2003, 11:31 AM
Brian M's Avatar
Dealer : Sand Dollar Toyota Scion
2003 Toyota Sequoia
Last Online: 07-17-2008 08:55 PM
Brian M is on a distinguished road.
Send a message via AIM to Brian M Send a message via Yahoo to Brian M Brian M's Photo Albums
Cycling is almost always indicative of low freon. That is almost always a sign of a leak. Some people will try and tell you that cars just lose freon...but I never believe that crap.
I had a '74 Corolla that went to its grave with the same freon it came from Japan with in the system. Never needed any.
2003 Sequoia SR5 - Phantom Gray
2006 F150 SuperCrew Lariat - Black/Gold
Old 05-20-2003, 12:12 PM
goddsmack's Avatar
Dealer : Elk Grove Toyota Scion
2002 Toyota Tundra
Last Online: 11-17-2008 01:59 AM
goddsmack is on a distinguished road.
goddsmack's Photo Albums
Normal operation, it's simply the compressor turning on and off based on the temperature increase through a thermostate, think of it as a climate control trying to stay at a particular temperature.
Bookmarks
