This is a discussion thread titled "Transmission Fluid Level doesn't fluctuate much!", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-19-2003, 01:41 PM
Tundra Thunder's Avatar
Dealer : Piercey Toyota Scion
2000 Toyota Tundra,
2001 Toyota Prius Fun!
Last Online: 12-19-2008 07:37 PM
Tundra Thunder is on a distinguished road.
Tundra Thunder's Photo Albums
Default Transmission Fluid Level doesn't fluctuate much!
My transmission fluid level doesn't seem to fluctuate much between the hot and cold settings. When tranny is cold the fluid level is between the cold notches. After some highway driving the fluid is a slighty above the last nutch from cold section (between the hot and cold notch sets). It is very confusing. Isn't it suppose to fluctuate up and down? Am I to low?
Thanks
Old 05-19-2003, 03:00 PM
Dealer : Stevens Creek Toyota
Last Online: 11-25-2008 12:55 AM
akauth is on a distinguished road.
akauth's Photo Albums
Default Re: Transmission Fluid Level doesn't fluctuate much!
Thanks
After 20 minutes of driving (normal - not high speed or extensive city) it should be between the two marks when it's hot.
What matters is not that it's between the two cold marks, but that it is correctly between the two hot marks after 20 minutes of driving.
After some extended high speed driving you should let it settle some before measuring.
Be sure you are reading it correctly. But it should be at least to the lower hot mark after you've been driving for a half hour or so. Sometimes the trans can be very hard to read. Be sure you are looking on both sides of the stick to determine fluid level. Some times it looks right on one side, but not quite right on the other. It's especially hard when the fluid is clean.
If you've got an issue, you can always stop by a dealer after you've driven it for a while and I'm sure they'll take a free look.
Alan
Old 05-19-2003, 03:46 PM
2000 Toyota Tundra,
Default Re: Re: Transmission Fluid Level doesn't fluctuate much!
Alan
Thanks Alan, I will take a look again.
Old 05-20-2003, 09:21 AM
sdmahr's Avatar
Dealer : Frank Smith Toyota
Last Online: 12-13-2007 04:23 PM
sdmahr is on a distinguished road.
sdmahr's Photo Albums
20 minutes may not be enough time to fully bring the auto-trans up to temperature. I had one truck where I installed a transmission temperature gage and under no "tow-load", it maintained a cool run temperature of 140-160 F. The only time I have ever been successful at really raising trans temperatures is an extended drive, (say 100 miles + at highway speeds), or towing a very heavy load in stop and go traffic or up hills. Perhaps the "hot" on the Tundra dipstick really means "hot", (which would make the fluid expand enough to reach the hot range on the stick).
My trans level in the Tundra behaves just as yours does Tundra Thunder. I gave up checking mine warm because I couldn't ever get it up to that level when warm. I start mine, go through the gears, and check it cool and make sure its on the higher side of the cool marks. I felt this was safe.
Bookmarks
