This is a discussion thread titled "Trans and Locker ?'s", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-20-2003, 12:49 AM
03TundraTRD's Avatar
Last Online: 03-15-2007 08:11 PM
03TundraTRD is on a distinguished road.
03TundraTRD's Photo Albums
Default Trans and Locker ?'s
I have a 03 Auto V6 Tundra 4x2 my question what size is the rear end is it a 7.5'' or 8'' and what locker is the best for some light off-roading like going in the sand and for better dry road traction. And my other question is does the Taco, Runner and Tundra have the same transmission if so can the valve bodies be swaped. The reason is I might have the trans bullet proofed by www.level10.com (check www.Gadgetonline.com for more info)
and I have to send them the valve body to them to work on it and I do not want my truck to be down.
Zach
Old 05-20-2003, 11:39 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
dyogim will become famous soon enough.
dyogim's Photo Albums
The rear end is a 8.25". Here's some info on toyota diffs front and back:
http://home.off-road.com/~bibelheime...diff_info.html
Old 05-20-2003, 04:41 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
Last Online: 03-27-2008 09:05 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
http://www.levelten.com
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
Old 05-20-2003, 07:46 PM
thecarguy's Avatar
Last Online: 02-13-2004 06:40 PM
thecarguy is on a distinguished road.
Send a message via AIM to thecarguy thecarguy's Photo Albums
I assume the V6 engine uses the same tranny regardless of the appliation. Power trax makes a good locker but its always engaged (eats tires and tires always chirp in turns). Your looking at about $400 for a selectable unit.
Old 05-20-2003, 08:50 PM
I thought the powertracks lock right disengages when you make a turn if thats not the case then what i a good selectable locker
Old 05-20-2003, 09:36 PM
v8Toilet's Avatar
www.powertrax.com
LOL!
stock exhaust
TRD LSD
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Old 05-21-2003, 03:10 AM
V8 Thanks for the web site it cleared up what I needed to know.
Looks like I am going to get the Lock-Right
Old 05-21-2003, 07:29 PM
thecarguy's Avatar
Ill say this....
I dont want to discourage from buying it if this is really what you want but here are a few things to know before you buy...
I have one and so does my buddy and tire wear is faster than stock, not real bad but noticable.
yes it does unlock, once youve started turning so the begining of your turns you have chirpy tires and while your turning its constantly locking and un locking, if you look at the spider gear replacements youll see what I mean (they are hevily notched). The locking and un locking is quite noisy however with the stereo on at a moderate level its not noticable.
You definatly have to take turns slower due to the fact that the unlocking of the diff has a slight lag to it. However with no other cars around its fun to spin out in the rain and snow and off road.
Long turns on a freeway or at freeway speeds are hairy, the back ends keeps wanting to slide out, you just gotta watch it and slow it down a tad. My buddy (one of the most cautious drivers around) spun a 180 on a freeway on ramp and i was looking right at him, a very hairy situation.
we both noticed extreeme clutch wear. A clutch wont last more than year, and the original clutch lasted 150K miles on an open diff. One Center Force dual friction clutch went out in about 7 months and a stock toyota clutch went out in about 3.
These were just some things to consider. BTW we both still have the units installed (1989 and 1991 toyota 4x4's) and are very happy with them regardless of a few downfalls.
Old 05-21-2003, 08:23 PM
DAMN thats kinda scary because most of the roads here on Guam are made from coral and when it rains I slide out very easely on these roads. Also I drive kinda fast I think I have to really choose what I want Traction or Saftey.
Old 05-22-2003, 12:24 AM
thecarguy's Avatar
there are also cable, air, and electronic lockers as well as limited slips.
Old 05-22-2003, 11:09 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
I have the Lock Right locker in my tundra and the descriptions thecarguy provided are true. However, it's not too bad. I have a heavy foot myself and I have not spun the truck(knock on wood). The advantages offroad are great. I've gone through obstacles where I would need momentum and or the tires would spin. I don't regret installing it. It's affordable and easy to install. You can go to www.toy4x4.net to check out the write up on the install. Mike Ross(Pres. of the Norcal TTORA chapter) helped me install it. I got the locker from another TS member unused for $280.
Mike
Old 05-23-2003, 06:15 PM
thecarguy's Avatar
I got mine from downey for $250. The advantages highly out weigh the few downfalls.
Old 09-18-2003, 02:39 PM
Last Online: 12-28-2008 10:32 PM
jorkep is on a distinguished road.
jorkep's Photo Albums
Default Powertrax
the powertrax noslip system is better than the lockright. it is more expensive, but in the long run it is better on the road so it won't eat tires as fast. Plus, selectable lockers start at about $650.
Old 09-20-2003, 10:56 PM
icarusarna's Avatar
2003 Toyota Tundra
Last Online: 12-04-2008 11:36 PM
icarusarna is on a distinguished road.
icarusarna's Photo Albums
is the POWERTRX No-Slip System like average LSD like the TRD one? little confused a bit on this one.
Old 09-20-2003, 11:06 PM
No, the Powertrax is not an LSD. It is a full locker, but it is made to have better on road manners.
http://www.4x4wire.com/reviews/no-slip/
This link will let you read the install of a noslip, and the review of it on and off-road.
Bookmarks
