This is a discussion thread titled "4.56 or 4.88", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-20-2003, 07:00 AM
03TundraTRD's Avatar
Last Online: 03-15-2007 08:11 PM
03TundraTRD is on a distinguished road.
03TundraTRD's Photo Albums
Default 4.56 or 4.88
What are the pros and cons for installing these gears on a v6 auto with stock tires or 20''
Old 05-20-2003, 07:20 AM
TRDKEAU's Avatar
Dealer : Carson Toyota Scion
2006 Toyota 4Runner
Last Online: 07-24-2008 12:36 PM
TRDKEAU is on a distinguished road.
TRDKEAU's Photo Albums
regearing: more torque, sets gears back to stock settings when using bigger tires.
cons: expensive..gas mileage goes down. High revs on the freeway.
I would save my money and get a v6 supercharger instead.
Old 05-20-2003, 07:49 PM
thecarguy's Avatar
Last Online: 02-13-2004 06:40 PM
thecarguy is on a distinguished road.
Send a message via AIM to thecarguy thecarguy's Photo Albums
I would only re-gear for a larger outside diameter tire. If youve got a 20" wheel but the outside diameter of the tire is still roughly 31" you will be fine. For speed/torque id make modifications elsewhere ie: shift kit and engine.
Old 05-21-2003, 10:19 PM
Cyanide41's Avatar
2003 Toyota Tundra
Last Online: Yesterday 12:36 PM
Cyanide41 is on a distinguished road.
Send a message via AIM to Cyanide41 Send a message via Yahoo to Cyanide41 Cyanide41's Photo Albums
Why would the gas milage go down? I would think it would go up, The truck is not trying so hard to turn the big tires after re-gearing.
Old 05-21-2003, 10:53 PM
TMS2U's Avatar
Moderator
Dealer : Longo Toyota
Last Online: 12-30-2008 12:30 AM
TMS2U is on a distinguished road.
TMS2U's Photo Albums
MPH goes down dur to the higher rpms that the engine runs, especially at freeway speeds.
Check out THIS SITE for a breakdown on the calculations with different ratios and tire sizes
Old 05-21-2003, 11:12 PM
Cyanide41's Avatar
2003 Toyota Tundra
Do you mean MPG?
Old 05-21-2003, 11:15 PM
TMS2U's Avatar
Moderator
ooooops
Yeah MPG goes down overall and MPH will lower at a given RPM
Old 05-23-2003, 08:19 PM
Dealer : Toyota Scion of San Bernardino
Last Online: 11-26-2008 02:55 PM
Leathernuts is on a distinguished road.
Leathernuts's Photo Albums
I thought the same, MPG goes up. But i see the whole pic about higher RPMS at freeway speeds. It probaly all balances out. Now you use less to get get going, but more at highway speeds and vice versa.
7"Front lift 315/75-16 BFGoodrich AT's on 16x8 MB Motoring with TC lift, Team West Coilovers, Deaver 3 leaf spring pack on 4" block with Bilstein 5100's in rear; Volant Intake; Spin-Tech Muff
Old 05-26-2003, 12:00 AM
Ok, but Guam does not have any highways and the speed limit is 45 mph so is the 4:56 overkill or should I stay with stock gears.
I am going to run 18x8 rims with 275/60
Old 05-26-2003, 08:02 AM
TRDKEAU's Avatar
2006 Toyota 4Runner
I wouldnt worry about it. V6 superduper would only be a couple hundred more than regearing and definitely a better mod, especially if your going the street truck route.
Old 05-26-2003, 09:59 PM
Y2kn1Tun's Avatar
Last Online: 04-27-2008 03:26 AM
Y2kn1Tun is on a distinguished road.
Y2kn1Tun's Photo Albums
Doesn't the S/C run like 3k, new gears for a 2wd would cost like 400 bux, with a locker about 600-800.
I think that 4.56's will work really well for your setup, especially since the speed limit is 45 mph. Joe has some 4.56's with 33's, and he's got the V8. Since you have the V6 I think it'll be perfect.
Old 05-27-2003, 08:08 AM
TRDKEAU's Avatar
2006 Toyota 4Runner
nope there less than $2000, I think you can pick up one for 1750 and its only a 3 hour job. I would much rather have this than regearing. IMO. I lived in low speed limit islands, its not fun either way you go.
Old 05-27-2003, 07:39 PM
Guys thanks for all the replys but what about I f I do a 3'' lift w/ 188 rims w/275/65/18 would I need to regear.
Old 05-28-2003, 05:56 AM
TRDKEAU's Avatar
2006 Toyota 4Runner
NO
Old 05-28-2003, 06:46 AM
Y2kn1Tun's Avatar
I've never lived there, but going that slow sounds like it sucks.
Bookmarks
