Old 12-14-2008, 03:53 PM
Last Online: 12-17-2008 01:17 AM
cotoyotafixer is on a distinguished road.
cotoyotafixer's Photo Albums
Default DIY 4-wheel drive actuator and blinking light problem?
I have a 2003 Sequoia. It has been trouble free until now. I now have the dreaded 4-wheel drive blinking orange light problem that has hit many Toyota SUV and truck owners. The blinking orange light does not turn off indicating that the 4x4 drive is not engaging. I have researched this at length and the problem according to most is either the center transfer case actuator or the front differential actuator, also known as the Automatic Differential Disconnect (ADD).
I have read that the problem is sometimes just corrosion, corroded electrical contacts in the actuators, or a just little lubricant. Worst case would be damaged gears in the transfer case or front differential. I want to remove, clean and bench test the actuators before I drop hundreds of dollars on a new ADD (I have heard $800 for just the part). I love my shade tree mechanic projects and take my cars to the dealer as the last possible alternative!
Here is my question. I have tried to remove the center actuator from the transfer case. The electrical connectors, breather tube, and three bolts come out with ease; however, I can only slide the actuator back about ½ inch and it does not want to come out any further. I have not yet put a pry bar or hammer to it for fear of damage. Is the shaft that is coming out of the transfer case connected to the transfer case or to the actuator? Is there some pin or clip I am not seeing?
I assume there will be a similar issue with the front differential actuator. I can see and get to the 4 bolts, but have not tried to remove the front one yet.
Has anyone removed and replaced their center or front ADD actuators on their own? I have tried to find a detailed DIY thread on this. Any advice and step-by-step guidance would be helpful to me and hundred of others that want to fix their electric (#@$%!) 4-wheel drive and keep $1,000's in their pocket! THANKS!
Old 12-18-2008, 03:14 PM
RogueRider's Avatar
Get off the pavement!
Dealer : Toyota of Dallas
2001 Toyota Sequoia,
2007 Toyota Camry
Last Online: 11-13-2009 07:34 PM
Images: 9
RogueRider is on a distinguished road.
RogueRider's Photo Albums
Default Re: DIY 4-wheel drive actuator and blinking light problem?
I looked at the 2001 sequoia repair manual. Same T-case as the 2003. The Transfer Assembly repair manual shows 2 snap rings on the gear shift fork shaft which is part of the actuator assembly. Removal of the snap rings to remove the actuator assembly requires opening up the transfer case.
Front differential carrier repair manual disassembly procedure shows that the ADD actuator can be removed from the front diff without opening up the diff. It's the first thing removed when dissasembling the front diff and the last thing installed when reassembling. You'll need to clean off the old FIPG and apply new when you r&r the ADD actuator. I've never done either of these jobs.
Old 12-18-2008, 09:12 PM
Dealer : Price Toyota
Last Online: Yesterday 08:53 AM
chinaloy is on a distinguished road.
chinaloy's Photo Albums
send me a pm with your email address and I can send you the corresponding pages of the service manual.
Tags
4 wheel drive , actuator , blinking light , differential , transfer case
