This is a discussion thread titled "Help Engine woes", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-24-2003, 01:09 PM
paulydee's Avatar
Last Online: 01-13-2007 09:24 PM
paulydee is on a distinguished road.
Send a message via AIM to paulydee paulydee's Photo Albums
Default Help Engine woes
Hey Gang,
I just started doing a 30K service. I changed oil and filter, replaced fuel filter and replaced spark plugs. I drove it to go get more parts but now anything more than 1/3 throttle the truck bogs and sputters. During the plug change I accidentally pulled of one of the hoses that goes to the charcoal canister (the hose with the green port on it). Does this have anything to do with the problem?
Any advice for stuff to start looking at would be appreciated.
Paul
Old 05-25-2003, 02:10 AM
Dealer : Jim Lynch Toyota
2006 Toyota Tacoma
Last Online: 06-19-2007 10:02 PM
Mudog715 is on a distinguished road.
Mudog715's Photo Albums
Default Re: Help Engine woes
Originally posted by paulydee
Hey Gang,
Paul
Sounds like you introduced an air leak, which will significantly lean out the mixture. The other likely cause is an unplugged or damaged MAF (mass airflow) sensor, but that will usually set the "Check Engine" light.
Listen for rushing air noises with the engine idling. The breather hose from the Right valve cover to the air inlet pipe baffle pops off easily and would cause such symptoms.
Good luck!
Old 05-25-2003, 09:32 PM
Toy4ever's Avatar
Last Online: 11-06-2005 12:22 AM
Toy4ever is on a distinguished road.
Toy4ever's Photo Albums
Check your MAF sensor, unplug the battery and then hook it back up. It should reset the computer and allow the engine to run normally again. Make sure the hoses you disconnected are all connected back to the proper locations also.
Old 05-26-2003, 12:47 AM
paulydee's Avatar
Red face I get the dumb *** award
Thanks for the advice guys, but some how I figured out today that I forgot to remove the hose clamp I installed to change the fuel filter. It didn't dawn on me because the car ran fine. I was going to change the fuel filter agaion and then the light bulb came on.
I feel like a knob.
Lesson learned.
Old 05-26-2003, 12:59 AM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 01-01-2009 05:17 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
Default Re: I get the dumb *** award
I feel like a knob.
Lesson learned.
Hey dont worry it happens to ALL of us. At least you figured it out.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Bookmarks
