Old 05-29-2003, 11:24 PM
Dealer : Capitol Toyota Scion
2002 Toyota Tundra
Last Online: 07-31-2009 04:23 PM
Jeffreyisbald is on a distinguished road.
Jeffreyisbald's Photo Albums
Question 4wd low button problems
Ok i just got back from the collision center and they told me that the 4wd button doesnt click in just like the 4wd hi button does.. because when I press the 4wd hi it goes in and stays in 'till i re-press it, and the 4wd low just doesnt stay in.... Is anyone else experience this problem? or is it just like that.. help.. i'm tired of leaving my car in shops...
2002 Toyota Tundra Limited 4WD i-Force V8
SnugTop tonneau
40series flowmasters dual exhaust
JL 10W7
1000w amp
1.5mFD cap
Panasonic Deck
Billet Grill
Clear Corners
Blue HID's
Yellow Fog Lights
Throttle Body Spacer
AEM Brute Force Cold Air Intake
Air Vent Shield Rain Guards
5% Tint all around
Debadged everything but the Iforce v8, LIMITED, & 4WD
Limited moved to the tailgate
Old 05-29-2003, 11:48 PM
DJ DJ is offline
Dealer : Fowler Toyota
2001 Toyota Sequoia,
DJ will become famous soon enough. DJ will become famous soon enough.
DJ's Photo Albums
It's like that, by design.
You can shift from 2 Hi to 4 Hi, and vice-versa, while moving. I remember the manual stating you can do this up to 55 mph, and I've done so.
If you're in 2 Hi, just push the "hi" button in -- it stays in and the transfer case shifts to 4 Hi. If you're in 4 Hi, just push the "hi" button again -- it pops out and the transfer case shifts to 2 Hi.
To shift to 4 Lo, you must already be in 4 Hi. Stop moving, put the gear shift in neutral, and press "lo" -- the button doesn't stay in, but the transfer case shifts to 4 Lo. If you're in 4 Lo, stop moving, put the gear shift in neutral, and press "lo" -- the button doesn't stay in, but the transfer case shifts to 4 Hi.
Why doesn't the "lo" button stay in?
Because you can shift from 4 Lo directly to 2 Hi. If you're in 4 Lo, stop moving, put the gear shift in neutral, and press "hi". The botton pops out and the transfer case shifts from 4 Lo to 2 Hi. If the "lo" button stayed in, this wouldn't work, but people would try to do it anyway.
Why does the "hi" button stay in?
Beats me.
