This is a discussion thread titled "Engine Noise Cold", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-30-2003, 04:11 PM
Last Online: 09-25-2004 04:25 PM
batlwagon is on a distinguished road.
batlwagon's Photo Albums
Default Engine Noise Cold
When engine is cold I can hear a ticking like noise when under acceleration.It seems to go away completely after a mile or so. I suspect an exhaust leak.Possible a cracked manifold.
Anyone have the same problem? If so did you have it looked at and repaired? Are there any TSB on this subject?
2001 Tundra
Any help appreciated.
Thanks
batl
Old 05-30-2003, 04:22 PM
Genthar's Avatar
Last Online: 11-18-2008 05:40 PM
Genthar is on a distinguished road.
Genthar's Photo Albums
A cracked exhaust header would be my guess as well. It seems a number of people have had this problem. No TSB's that I'm aware of, just need to replace the exhaust headers. Good opportunity to upgrade to an aftermarket header.
Genthar
Old 05-31-2003, 08:12 PM
Last Online: 11-01-2003 07:38 AM
teebonetuna is on a distinguished road.
teebonetuna's Photo Albums
My 2001 ticks but noticed that when I changed oil to 10-30 mobil 1 from 0-30 tick is not as loud and goes away quicker. dealer said all tundras make noise when cold. Tick was there when using 5-30 as well.
Old 06-10-2003, 11:38 AM
acme's Avatar
Dealer : Northridge Toyota
2003 Toyota Tundra
Last Online: 11-19-2008 03:58 PM
acme is on a distinguished road.
acme's Photo Albums
Smile Oil
I'm using 0-40 wt. Mobil 1 Synthetic oil after my first change and no ticking and oil pressure stays above the lower line on the gauge....
You can use it in winter and summer heat and it's rated "Fuel Conserving" . Alan
2003 Tundra
Old 07-10-2003, 04:39 PM
Default it's the exhaust headers
Took it to the dealer Monday
Going to replace both headers.
That's just @#%&*% great for a new truck with 11,000 miles on it
I'm Jacked
It'll never be the same
I think they have to pull the engine out.
Dam it
Ohh what a feeling.........I can get that in prison for free!
Old 07-10-2003, 05:29 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 03:11 PM
DevinSixtySeven is a splendid one to behold. DevinSixtySeven is a splendid one to behold.
they dont need to pull the engine .
if ya wait a few bits, s&s has some beauties coming along...see the thread "a potential new header manufacturer" i think is the name .
bad welds + bad design = cracked manifolds. dont worry, it seems to be the only major brain-dead design feature on the truck...
-sean
GFX by FreedomEagle50
Manual Hubs
Old 07-10-2003, 05:50 PM
Genthar's Avatar
Default Re: it's the exhaust headers
I'm Jacked
Dam it
Shouldn't really be a problem. They don't have to yank the engine to replace it, though I don't know what their service manual calls for. Plenty of people have replaced theirs without pulling the engine. And no, it'll never be the same, it'll be better because the ticking will be gone.
Genthar
Old 07-10-2003, 11:20 PM
Last Online: 10-01-2003 02:51 AM
indecline is on a distinguished road.
indecline's Photo Albums
2001 Tundra
Thanks
batl
Looks like the dealer already diagnosed the problem, however fuel injectors have a habit of making ticking sounds when they are cold too....
Old 07-14-2003, 11:52 PM
Kdog's Avatar
Dealer : Toyota of Greer
Last Online: 07-12-2008 09:19 PM
Kdog is on a distinguished road.
Kdog's Photo Albums
Default My 2001 does this too
I read somewhere that the Toyota overhead cam design causes this "ticking" until the oil gets dispersed through the engine? I don't know if this is true. Is there a way to check for a cracked header before I take it to the dealer?
Old 07-15-2003, 12:26 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 01-02-2009 07:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
With the truck cold, listen under the front wheel well on each side while you have someone start it up and put it in drive with the brakes on. With the brakes held firmly, have them give it some gas. If the manifolds are cracked, you should be able to hear the leak under those conditions. Just to be sure, I put a length of small diameter hose up into the area by the manifold flanges and listened at the other end. I found my leak at the front flange on the driver's side. The truck had about 27K on it at the time. JBA makes a good cure for the cracked manifolds.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 07-15-2003, 03:35 PM
true !
...and taking it to the dealer to have them replace the manis will get those bolts loosened for ya so it's easier to install the JBAs (or whichever header you went with).
-sean
Manual Hubs
Old 07-22-2003, 10:34 PM
Default Headers Replaced
Dropped the truck off Wendsday night (07/16/03), they gave me a loaner to drive. When I got home from work (2:30 pm EST) there was a message on my machine that my truck was done .
I picked it up , did a walk around, and seeing no damage to paint ,ect. I left.
It's been around 5 day's now and the noise is gone , no ill effects to the truck and I am Happy.
I must apologize for my previous Flaming.
I am a mechanic, have been for 20+ years , I mostly work on heavy equipment, tractor trailers , backhoes , wheel loaders, paving equipment. I work for the local municipality.I have worked on scores of light vehicles also including my own, friends? and family.I drove a 78 olds 98 for 15 years due to my tender loving care. I bought the olds for $150.00 ,(put a timing chain , camshaft, lifters and rebuilt the carb and did ordinary stuff over the years).
My b!t(h is , I'm tired, this is the first vehicle I've bought brand new, I'm 41.I don't want to come home and work on any vehicles. I bought this Toyota figuring there suppose to be high quality ,and I should get some great mileage from this truck I should'nt have to touch it except for the regular mantinence.
2 years in, with 11,500, I have, "Warped Manifolds". As you can see I don't put alot of miles on, and yes I bought the extended warranty , 6 years, but I wanted to keep this truck. I don't want to put headers on , I don't want to debadge it , I don't want to do anything to it. I just want to drive it and do as little as possible to it. I certainly do not want to be putting headers on it every two years after it's out of warranty!
$78.00 an hour labor : 10.4 hours Labor: Plus Parts! :2003 Prices!
I Expected Better!
Batl
Old 09-23-2003, 11:55 AM
Kdog's Avatar
Kdog's Photo Albums
Default If I don't get it fixed right away what problems can it
lead to??? I found out it's not covered under my extended warranty.. sucks!
Bookmarks
