Old 02-12-2009, 03:20 PM
Last Online: 09-08-2009 11:12 AM
28gauge is on a distinguished road.
28gauge's Photo Albums
Default Spark Plug Help
I have a 2006 Tundra with 25000 miles and I'm going to change the plugs. My manual says they're irridum, but does not give a gap. What plugs do you recommend and what is the gap? Also, is there anything else I need to know? It looks like you take off the outer small bolt that's holding down the wire cover, remove it from the plug and then change the plug in the usual manner. I'm thinking maybe NGK plugs, or should I stay with Toyota?
Thanks.
Old 02-12-2009, 03:57 PM
Dealer : Toyota of Killeen
2004 Toyota Tundra,
1999 Toyota Land Cruiser,
2008 Toyota Camry-Solara SLE Convertible
Last Online: Yesterday 11:54 AM
labountyphoto is on a distinguished road.
labountyphoto's Photo Albums
Default Re: Spark Plug Help
go to Spark plug, Spark plug wire, spark plug gap, spark plug cross reference and ignition wires at Sparkplugs.com. they sell several types of plugs and will list the specified gaps per model. (.032 for most 4.7's, i think) Toyota uses either NGK or Denso or a mixture of both, sometimes.
Yes, remove the bolt(10MM ithink) and pull the coil pack. Replace the plug and the coil pack. It's a piece of cake. You will need about a 6'' extension and a good plug socket as the plug is recesssed.
If your plugs are iridium, you shouldn't need to replace them yet. They should last close to 100k. They are expensive.
I used Autolite platinums (AP3923) from Walmart in both my 99LC and my tundra. I changed them on the LC at 70K, though it was running fine, and noticed no difference when I changed them.
Old 02-12-2009, 05:38 PM
Dealer : Stevens Creek Toyota
- Other - 2006 Highlander AWD
Last Online: 11-20-2009 04:35 PM
ddvk is on a distinguished road.
ddvk's Photo Albums
Goto the stealership and buy it, OTC plugs are detrimental to the coils and timing.
BTW, the plugs are designed for 100K, why replace so early?.
Old 02-12-2009, 06:03 PM
Bakemono's Avatar
Dealer : Hesser Toyota Scion
2009 Toyota Tacoma regular cab 4x2
Last Online: 08-09-2009 09:59 PM
Images: 3
Bakemono is on a distinguished road.
Send a message via AIM to Bakemono Bakemono's Photo Albums My eBay
Iridiums come pre-gapped and you cant regap them (the electrodes are so hard that they will break if you try to).
I wouldnt buy them for the dealer, just go to your local auto parts store and buy them. They are no different than the ones you buy at the dealership and will be less expensive.
Make sure you stay with either Densos or NGKs.
All the best stuff is made in Japan.
Originally Posted by Tundra_Hick View Post
The Tundra is a good single guy's truck. Its pretty, it doesn't rattle too much and its fast. Now I just need to find a woman who matches in all those respects.
Old 02-15-2009, 03:48 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: 06-02-2009 12:03 PM
kathyricks's Photo Albums
Your manual says do not adjust the gap and your manual says exactly what Denso plug to use. Auto parts store Denso's & NGK's may come with wider gaps than your factory original plugs (which hurts performance & fuel economy) because they are intended for a bunch of different car makes so it's safer to buy genuine Toyota Denso's from a discount Toyota dealer like Bob Bridge Toyota (1sttoyotaparts.com) whose prices are comparable to sparkplugs.com, Autozone, etc.
Save your factory original plugs so you'll always know what gaps the factory originals were set to.
25K miles is kinda early to change iridium plugs, but it's good to change them more often than the factory manual 120K mile interval to maintain top fuel economy which in turn mimimizes emission system deterioration and the associated possibility of needing TWO new $1000 catalytic converters at around 100-150,000 miles.
Old 06-26-2009, 09:09 AM
Dealer : Valenti Toyota
2005 Toyota Tundra
Last Online: 09-20-2009 06:14 AM
dougg is on a distinguished road.
dougg's Photo Albums
Thumbs up Re: Spark Plug Help
they are good for 100,000 miles. BUT take them out at 30,000 inspect and put back in using thread anti-seize. they are about $12 each. doug
Old 06-26-2009, 08:26 PM
kerryman71's Avatar
Dealer : Harr Toyota
2002 Toyota Tundra SR5 AC V8 4X4 TRD
Last Online: Yesterday 10:54 PM
Images: 27
kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything.
kerryman71's Photo Albums My eBay
As Dougg mentioned, use some anti-seize on the threads of the plugs
when you replace them or if you just check and reinstall the ones
that are there now. You can usually buy a pack of the stuff for .99 cents.
I use it so much I own a container of it. I also use dielectric spark plug
grease in the ends of the coil packs before putting them back in.
Old 06-27-2009, 12:05 PM
ddvk's Photo Albums
No antisieze on plugs as they contaminate O2 sensors (though antisieze says sensor safe). Put some gear oil on it and tighten it to 10-20 lbs.
Yeah, 30K is too early. I would not touch it till it hits 80K (after that anyway u are on your own, you can put anything, NGK, OEM, OTC).
Sticking with OEM or what the owners manual details is my sound advice. I would just stick with stealership, just buy and install, they are already pregapped by OEM manufacturer to meet Toyota standards.
Old 07-16-2009, 05:03 PM
Quentin18's Avatar
2003 Toyota Tundra
Last Online: 11-15-2009 02:22 PM
Images: 2
Quentin18 is on a distinguished road.
Quentin18's Photo Albums
Hey, I have an 03 Tundra.
Do u know if the E3 Spark plugs are good ones? Im wanting to get a high quality spark plug, around 6$. What would u guys get?
Tundra with a little lift and 33's
Old 07-16-2009, 11:23 PM
Highwaylizard's Avatar
Dealer : Butler Toyota Scion
2004 Toyota Tundra Limited DC 4.7 4spd
Last Online: 11-17-2009 06:13 PM
Images: 64
Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all.
Highwaylizard's Photo Albums
Are you saying that a wider gap hurts fuel economy and performance? I had .030 in the truck and replaced with .040 (Denso). My highway MPG's are up at 20 MPG for the first time since I have owned the truck.
Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with True Flow foam filter, Mobile 1 in the engine, K&N oil filter, Royal Purple in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires.
testis amotio per pera
150,620miles on the odometer Tundra Fuel Economy Blog
19+ MPG on the Highway at 75 MPH in a DC with a four speed automatic and a bad O2 sensor - not too shabby!
Old 07-25-2009, 07:32 AM
shall36's Avatar
Dealer : Central Florida Toyota Scion
2003 Toyota Tundra
Last Online: Yesterday 01:54 PM
shall36 is on a distinguished road.
shall36's Photo Albums
I've used Anti-seize on all my plugs, even in iron heads, for 20 years and I've never had a problem with contamination. I wouldn't think of installing plugs in aluminum heads without anti-seize.
On the broader topic:
1. 25K is way too early. Find another project
2. As expensive as these plugs are, source them online.
3. NGK or ND will do just fine. No need to go to the dealer. I wouldn't use any other brand, regardless of how impressive their ads are.
4. A difference in gap of .030 to .040 won't hurt anyone. If you put a plug in with a gap of .090, that might be a problem.
http://www.daveramsey.com/
Must See Video: Drive Free Cars for Life
Old 09-11-2009, 10:35 AM
Dealer : Mechanicsville Toyota
2007 Toyota FJ Cruiser
Last Online: 11-23-2009 07:15 PM
prsrcokr is on a distinguished road.
prsrcokr's Photo Albums
Just a note, irridium should never be adjusted. The electrode is very fragile and can crack easily, that's why they tell you not to gap these.
Agreed to use antiseize, but only a very small amount is needed. putting excess on can damage emissions equipment. Also, the gap can and does make a difference. More gap = more spark which can mean a more complete burn. Of course at some point the gap is too big for the ignition system and can 'blow out' or not ignite causing a misfire (more common on forced induction stuff) If you've ever seen bad plug wires arc you know the spark can jump a good amount. It's the quality of the spark that's important.
I'm seeing a slightly rough idle at 65k (06' DC) I guess I'll pull the plugs to see how they look, didn't realize they're intended for up to 100k. Figured it might help mpg too.
Brian
"Only two things are infinite, the Universe and human stupidity...I'm not so sure about the Universe" - Albert Einstein
06' Tundra DC SR5
88' Supra turbo (track/auto-x car)
07' FJ 6-speed (wife's)
98' Tacoma Limited (sold)
