Old 04-02-2009, 01:33 PM
kymatt's Avatar
2002 Toyota Tundra,
2005 Toyota 4Runner,
- Other - 1987 Chevy El Camino
Last Online: 11-18-2009 08:23 PM
kymatt is on a distinguished road.
Send a message via AIM to kymatt Send a message via Yahoo to kymatt kymatt's Photo Albums
Default 00 - 02 Owners: Does anyone tow with OD *ON*?
Just curious. Common practice (and good advice) dictates that us early first-gen owners tow with OD off due to a number of reasons, one being the weak planetary gear that some folks ended up with.
I've never had any problems with my tranny (knock on wood) but I don't tow much either.
I'm curious if anyone here regularly tows with OD on, and have you experienced any problems?
Old 04-03-2009, 12:03 AM
Derek24's Avatar
Dealer : Piercey Toyota Scion
Last Online: Today 01:08 AM
Images: 96
Derek24 will become famous soon enough.
Derek24's Photo Albums
Default Re: 00 - 02 Owners: Does anyone tow with OD *ON*?
When i used to tow my 21ft Boston Whaler i would have to leave it out of OD because of all the hills here, but on flat open road i would have it on. With over 100 gallons of fuel, the boat, trailer, and all the fishing gear im sure i was up to about 6500lbs and it towed it great and the truck runs as good as ever. But since fishing here in California is the thing of the past, OD is always on.
2000 Tundra TRD 4x4, 5100's(4th notch), procomp wheels, 265's, 14" Magnaflow single out, re-badged black, Push Bumper, Powertrax No-slip, Diff breather mod, clear corners, TC Bushings, Camburg UCA's, Wheeler's Anti-Swaybar bushings, 35%/5% tint
In the bed-RM250
Life's a bore, I'm going pig hunting...
Old 04-03-2009, 05:59 AM
cleanb13's Avatar
Dealer : Boch Toyota South
Last Online: 11-20-2009 05:38 PM
Images: 20
cleanb13 is on a distinguished road.
cleanb13's Photo Albums
I tow an enclosed snowmobile trailer with 2 450lb machines and gear with OD on several times every winter without a problem. So far.
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 BFG AT KO on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Magnaflow 11226 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate with custom made aluminum side shields, extended rear diff breather hose, Hawk LTS brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Downey Offroad front swaybar link kit and cv joint boots,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Viair 300P air compressor, blacked out mouldings, bumpers and grille emblem
Old 04-09-2009, 09:15 PM
Hi Volt's Avatar
Dealer : Sunrise Toyota - Abbotsford
Last Online: Today 03:38 AM
Images: 7
Hi Volt will become famous soon enough.
Hi Volt's Photo Albums
I have towed with and without it. But no one should tow heavy or jerky loads with overdrive on ANY truck ( it is inherently a weaker gear design in any brand). No manufacturer recommends using OD for towing so don't just believe all the reteric about Tundra trannys, all manufacturers have had their share of O.D. failures through the years. A number of manufacturers have switched to having a "TOW" button, which is really a disguised method of disabling O.D. amoung some shift pattern changes.
