Re: Question about replacing camshaft seals.
Remove the valve cover, then remove the CAM CAP, slide the seal out and then slide the new seal in, re-install the cam cap and seal it with FIPG (from in place gasket), re-install valve cover with new gasket.
The manual shows pushing the seal in, but it isnt that easy and it is easier to remove the V/C and cam cap then install the seal.
25 yrs with TOYOTA
