DIY: Check the Automatic Transmission Fluid Level
NEWS
+ Reply to Thread
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 60
Thread: DIY: Check the Automatic Transmission Fluid Level
  1. #1
    Assistant Administrator nhparrot would rather be driving his reputation. nhparrot would rather be driving his reputation. nhparrot would rather be driving his reputation. nhparrot would rather be driving his reputation. nhparrot would rather be driving his reputation. nhparrot would rather be driving his reputation. nhparrot would rather be driving his reputation. nhparrot would rather be driving his reputation. nhparrot would rather be driving his reputation. nhparrot would rather be driving his reputation. nhparrot would rather be driving his reputation. nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    59
    Posts
    6,431
    Liked
    5 times
    Rep Power
    685
    Lightbulb DIY: Check the Automatic Transmission Fluid Level
    • Park the vehicle on a level surface.
    • With the engine idling and the parking brake applied, shift the selector into all positions from "P" to "L", and then shift into "P" position.
    • Pull out the dipstick and wipe off the fluid with a clean rag. Re-insert the dipstick and check that the fluid level is in the HOT range.
    • Do this check with the fluid at normal driving temperature (70 - 80°C, 158 - 176°F) .
    HINT: Wait until the engine cools down (approx. 30 mm .) before checking the fluid level after extended driving at high speeds, in hot weather, in heavy traffic or pulling a trailer.
    If necessary add ATF DEXRON-II or DEXRON III
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter tempetom is a pinnacle in their own mind. tempetom is a pinnacle in their own mind. tempetom is a pinnacle in their own mind. tempetom is a pinnacle in their own mind. tempetom is a pinnacle in their own mind. tempetom is a pinnacle in their own mind. tempetom is a pinnacle in their own mind. tempetom is a pinnacle in their own mind. tempetom is a pinnacle in their own mind. tempetom is a pinnacle in their own mind. tempetom is a pinnacle in their own mind.
    Join Date
    May 2005
    Location
    Tempe, AZ
    Age
    73
    Posts
    1,549
    Liked
    6 times
    Rep Power
    1890
    Default Re: HOW-TO: Check the Automatic Transmission Fluid Level
    Glenn, I reckon that only applies to Tundras with a tranny dipstick.
  4. #3
    Rookie Rotryrkt is on a distinguished road.
    Join Date
    Jan 2006
    Location
    Lafayette, IN
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    How about the procedure for checking the trans fluid level on 2005 models with no dipstick!
    I tried yesterday while under there changing oil and greasing drive shafts. I have two plugs on the trans pan one a plain plug at the rear (drain?) and one with "check" stamped in it with a hex allen head. I removed this "check" plug assuming it was at the bottom of some sort of tube extending at or above the specified level in the pan. Logical, I thought, like most things Toyota. WRONG!! I got a face full of oil before I got it threaded back in. I figure I lost about a quarter pint of oil at most. I doubt this will have any effect, but I would like to know the correct procedure in any case for peace of mind. Anyone know the correct procedure, and where the fill hole is? I found what looks like a fill hole plug, but it is in the tail shaft housing between the trans and transfer case. Is that it? Thanks in advance for your help.
  5. #4
    Join Date
    May 2005
    Location
    Tempe, AZ
    Age
    73
    Posts
    1,549
    Liked
    6 times
    Rep Power
    1890
    I'm wondering if you were not on a level surface when checking the level? It's virtually impossible to overfill as I understand it. What you did was correct I think. I assume the "check" plug was on the side and the overflow plug was on trhe bottom. I suppose oil could come out if the tranny was hot shen checked.
  6. #5
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    59
    Posts
    6,431
    Liked
    5 times
    Rep Power
    685
    Thread Starter
    Quote Originally Posted by tempetom
    see attached
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  7. #6
    Join Date
    Jan 2006
    Location
    Lafayette, IN
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thanks folks for the response and to Glenn for posting the procedure from the shop manual. I talked to my local dealer today to confirm what I had done was right. He said it was, but the fluid needs to be up to temp and idling in park to do the check. It was warm but not running when I checked, so it probably had drained back into the pan what would normally be circulating causing too much to run out the overflow tube. I will certainly recheck it with the engine running to verify the proper fill.
    Thanks again tempetom and Glenn for the response. I'm sure this helps a lot of us "Barnyard Mechanics" used to having a dipstick to check oil levels.
    Regards,
    Bill
  8. #7
    Lurking Member tedm is on a distinguished road. tedm's Avatar
    Join Date
    Feb 2002
    Location
    Racine, WI
    Age
    64
    Posts
    41
    Liked
    0 times
    Rep Power
    11
    Question Re: HOW-TO: Check the Automatic Transmission Fluid Level
    Last week I took my 2005 DC to the Toyota dealer and asked him to check the Transmission fluid. He told me that he was not to check it, that it was good for the life of the truck. He said the thought that it was strange that that was what Toyota recommended.
  9. #8
    Rookie snobordr is on a distinguished road.
    Join Date
    Feb 2005
    Location
    Reno, NV
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    I accidently drained about .5 quart (or less) of transmission fluid out of my 2005 DC tacoma. Rather than trying to fill it myself I took the truck to the Toyota dealer. They told me that the transmission is a closed system, and that they are not able to "top off' the transmission fluid. The only thing that they could do was to do a complete transmission flush ($200). The mechanic didn't think that loosing .5 quart would be a problem, so I left without getting the fluid filled. I was wondering if the document posted by Glenn applies to Tacoma's as well as Tundra's? I would feel much better if I could add some fluid to get the level back to normal.
  10. #9
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    59
    Posts
    6,431
    Liked
    5 times
    Rep Power
    685
    Thread Starter
    see attached
    ~Glenn
    Yes I am a pirate!
  11. #10
    Lurking Member RCraig is on a distinguished road. RCraig's Avatar
    Join Date
    Oct 2005
    Location
    Sherwood, AR
    Posts
    47
    Liked
    0 times
    Rep Power
    7
    Have any of you (with a dipstick) noticed that it says "No need to change ATF under normal driving conditions." The Toyota service manual only mentions changing the ATF at 60,000 miles (if you use your vehicle for primarily for towing). The dealer says every 30,000 miles. A buddy of mine bought an '05 Tacoma 4X4. It doesn't have a tranny dipstick. The dealership told him that it was designed to be replaced only when the transmission "went out" or had to be serviced when there was a problem. Can you believe?
    2004 Toyota Tundra DC SR5 4X2 White w/Oak Interior / Toyota LSD / Tow Pckg / Chrome Pckg / 265/65R17 split 5-spoke aluminum alloy wheels
    Performance MODS - K&N FIPK / Flowmaster 50 Series (dual in dual out) / Helix Power Tower / JBA Titanium Headers
    Tundra Solutions MODS - DRL / Fog Light / Map Light / Rear Window / Power Outlet / Rear Shock
    Accessories - UWS Nerf Bars / Undercover Tonneau Cover / Rhino Bed Liner / Weathertech Vent Shades / Altamere Window Tinting / AVS Bug Shield / Stant Locking Gas Cap / Sylvania Silver Stars / Cooper Discoverer ATR tires
  12. #11
    Rookie slabman is on a distinguished road.
    Join Date
    Jul 2006
    Location
    Plano TX
    Posts
    8
    Liked
    0 times
    Rep Power
    0
    Unhappy Re: HOW-TO: Check the Automatic Transmission Fluid Level
    I assume this same tranny is what's used in the LX470? My dealer said the fluid was good for 100K miles, but didn't know how he was going to change fluid at that point in time. He thought maybe by then they would come out with something to allow him to do this. Strange, but why can't Toyota provide for the owner who simply wants to change fluid more frequently? I note those posted service bulletins do NOT address CHANGING the fluid, only checking and topping off.
  13. #12
    Rookie bwatters is on a distinguished road.
    Join Date
    Jul 2006
    Location
    Sacramento, ca
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    I have a 2001 4Runner and cannot find the dipstick for the transmission fluid. Last night, it would not reverse so I thought I should check the fluid before I try and drive it to the dealership. Can anyone tell me where I find the dipstick? I am not exactly mechanically inclined.
  14. #13
    Rookie tom33us is on a distinguished road.
    Join Date
    Aug 2006
    Location
    Detroit, MI
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default What kind of transmission fluid does a 2000 Corolla need?
    I've seen some threads where people are saying that Dexron III is fine, but a mechanic has just told me that the Toyota-manufactured ATF (known as "Toyota Red") is the ONLY fluid that should be put into the transmission because if it mixes with another type then the mixture begins to coagulate, which is bad times.
    Can anybody give me a 100% accurate rendering on this? Must a 2000 Corolla have ONLY the "Toyota Red," or can I use Dexron III?
    Thanks a bunch.
    -Tom
  15. #14
    Supporter fastman9 is on a distinguished road. fastman9's Avatar
    Join Date
    Jul 2002
    Location
    Oceanside, CA
    Posts
    175
    Liked
    0 times
    Rep Power
    10
    I've used Dex III for years with no problems.
  16. #15
    Supercharged Member HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD is a glorious beacon of light. HOGWILD's Avatar
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,522
    Liked
    1 times
    Images
    12
    Rep Power
    148
    Quote Originally Posted by nhparrot View Post
    see attached
    How would a 2.5 inch lift on front end affect the service on a 2006 Tundra Transmission? i suspect that it would change the level once the vehicle is raised but probably not enough to affect anything? any thoughts since i know a lotta people have raised their front ends to level their truck and was fixxin to do the same to my Tundra. I would carry to Dealership to check due to they should know how to do it IAW Toyota Guidance i hope?
  1. 05-02-2012, 03:06 PM
  2. 04-08-2012, 02:37 AM
  3. 03-30-2012, 01:11 PM
  4. 03-01-2012, 09:37 AM
  5. 01-12-2012, 05:52 PM
  6. 09-20-2011, 01:18 PM
  7. 04-19-2011, 05:00 PM
  8. 03-16-2011, 05:20 PM
  9. 02-16-2011, 06:47 PM
  10. 01-30-2011, 07:56 AM
  11. 06-03-2010, 12:34 PM
  12. 03-15-2010, 12:52 PM
  13. 01-14-2010, 09:00 AM
  14. 03-08-2009, 12:52 AM
  15. 03-06-2009, 12:47 AM
  16. 01-30-2008, 09:21 PM
  17. 12-07-2007, 08:10 PM
  18. 07-30-2007, 09:41 AM
  19. 06-08-2007, 02:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
