Old 05-21-2009, 02:25 PM
itwonder's Avatar
Dealer : Miller Toyota
2002 Toyota Sequoia
Last Online: 06-21-2009 09:30 PM
itwonder is on a distinguished road.
itwonder's Photo Albums
Default 97 Canry 1MZ idling fast
97 Camry 1MZ Automatic.
  • Idles ~ 800 RPM on cold start in 70 degree weather.
  • Hot idle ~1200 RPM.
  • Shorting TE1 and E1 on diag.connector brings idle to ~ 1050 RPM.
  • Turning A/C on drops idle to 800 RPM.
  • Can't find any vacuum leaks, idle vacuum 22"
  • Center IAC pin to each outer pin is 23 ohms.
The IAC has correct resistance, and drops to a little above specicifed RPM when diag. pins shorted. So I can't isolate problem to IAC. Any ideas?
Old 05-26-2009, 12:07 PM
2000tundra2wd's Avatar
Dealer : Ray Brandt Toyota of Metairie
Last Online: 11-07-2009 02:23 AM
Images: 14
2000tundra2wd will become famous soon enough.
2000tundra2wd's Photo Albums My eBay
Default Re: 97 Canry 1MZ idling fast
Disconnect the negative lead on the battery for 15. This allows the ECU to reset. Then, when you turn the car on after letting it reset, take it for a drive and be gentle with it, i mean dont punch it at every stopsign. See how it works from there, the computer just needs to reset.
2000 Tundra 2wd 4.7L
5% tint all around
Magnaflow part 14326
14 inch Single In/Out Open Muffler
Denso HID ballast.
Philips 4,300k d2r HID bulb
H4 to D2R Adapter
20 inch Toyota TSS wheels with 265/50r20 Toyo Tires
