This is a discussion thread titled "rear differential and thing that sticks out of it?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-25-2003, 02:57 PM
berzman's Avatar
Last Online: 05-06-2005 09:49 AM
berzman is on a distinguished road.
berzman's Photo Albums
Default rear differential and thing that sticks out of it?
i was told that if i disconected the arm/ cable thing that goes in to the top of my differental that my braking would become a true 60/40 all time. with the arm /cable thing conected the braking is a 80/20 what is the arm/cable lever thing called and whats the purpose of it ? thanks for reading
Old 06-25-2003, 03:13 PM
Dealer : Carson Toyota Scion
Last Online: 12-11-2008 11:55 PM
Alan is on a distinguished road.
Alan's Photo Albums
Exclamation
I believe it is called the Brake Proportioning Valve (BPV) and you don’t want to mess with it. Only time I’ve heard of the BPV being adjusted is to accommodate different geometry of a modded/lifted truck.
An 80/20 (or whatever the Tundra has) front to back ratio for braking power is preferable for many reasons. When needed, the BPV will adjust that ratio according to the amount of extra weight lowering the bed of the truck.
Stay shiny,
Old 06-25-2003, 03:49 PM
berzman's Avatar
thank for you're reply the person i had spoke with has had his disconected ever since he's owned his 2001 sr5 no problems in fact he says that the brakes work much better no conected. i'm not going to mess with it just unsure
Old 06-25-2003, 11:44 PM
DJ DJ is offline
Dealer : Fowler Toyota
2001 Toyota Sequoia,
DJ will become famous soon enough.
DJ's Photo Albums
The brake proportioning valve does NOT change the proportioning of front/rear braking, despite its incorrect name. It simply limits the MAXIMUM pressure that can be applied to the rear brakes, the idea being to prevent the rear brakes from locking up. When you add weight to the bed of the truck, the rear end lowers and the arm described makes the valve increase the rear braking limit. This works quite well -- the more weight you have in the rear end, the less likely you'll break the rear end loose on braking, so the more pressure can be allowed at the rear brake cylinders.
You risk a lawsuit by disconnecting it. Suppose you do, then lock up the brakes, spin out, and hurt someone. Would you have locked up the brakes with the valve intact? No one could say, but how would you defend yourself? Do you really need the risk, both of the accident and the liability?
Old 06-27-2003, 01:02 AM
lelandstanford's Avatar
2005 Toyota Tacoma
Last Online: Yesterday 06:06 PM
lelandstanford is on a distinguished road.
lelandstanford's Photo Albums
If you have ABS then there should not be any lockup problem.
Instead of removing the arm you can make adjustment for more rear brake pressure.
Load Sensing Valve Adjustment
2005 Tacoma AC 2WD 2.7L 5M
Bookmarks
