Old 06-25-2003, 10:15 PM
Verndog's Avatar
Dealer : Doxon Toyota
2003 Toyota Tundra
Last Online: 10-30-2009 07:17 PM
Verndog is on a distinguished road.
Verndog's Photo Albums
Default Please help with Dual Exhaust Question
I am going to run true dual exhaust all the way back. I've read tons of threads on this and still am not 100% on this crossover issue. I've read that you don't need crossover with 2 cats....and I've read that you do...
Question 1 will it improve performance to run crossover with 2 cats, and must it be before cats.
Question 2 after the dual cats should I use 2 resinators if I'd prefer to keep noise levels low.
Question 3 what mufflers would you recomend to keep noise levels low but not sacrifice much in the way of performance.
BTW...I'd rather spend a little more up front, and do it right...and I am having the work done at a local custom shop..
Thanx All
Kevin
2003 Silver Sky TRD SR5 V8 4x4 Access Cab
My 69 Mach 1 Pics
Factory Options:
TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
Appearance Mods:
PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
Performance Mods:
Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
Old 06-25-2003, 10:17 PM
keiphers's Avatar
Dealer : West Ashley Toyota
2002 Toyota Tundra Limited White TRD4x4
Last Online: 11-27-2007 02:19 PM
keiphers is on a distinguished road.
Send a message via AIM to keiphers keiphers's Photo Albums
I'd just use QuickTime performance electronic cutouts. Do a search for them. Member mjjoff has them.
2002 Limited TRD Tundra 4x4
Unichip / ASP Underdrive Pulley / K & N FIPK / Bassani Split Side Deuces / White Powdercoated ARB Sahara Bar with IPF 900XS lights and Warn M10000 Winch / Demello Offroad Sliders / ORS Manual Hub Conversion / TRD Limited Slip Differential / Fabtech Performance 3" Lift / Fabtech Performance Rear Shocks / Fabtech 1.5" Add-A-Leaf / 285/75/16 BFG All Terrains / Mickey Thompson Classic II's / Total Chaos Uniball Upper Control Arms / Total Chaos 1" Differential Drop Spacer / Bates Porsche 930 CV Boots / White C/R/C Taillights / TRD Radiator Cap / Molly Designs I.S. Grille w/TRD Emblem / Clear corners / 20% Tint / Better Built Quantum ATB Series bed box / White Rhino Liner / Odyssey PC1700MJT Battery / Wilson 4' White Fiberglass Whip / Cobra 29 WX NW ST CB/PA / Viper 791XV Responder w/530T Window Roll-Up/Down module / Focal 165K2 Polykevlar component set / U.S. Acoustics USX4085 amp / Alpine CDA-7998 / JL Stealthbox
2003.5 BMW M3
Supersprint Sport Exhaust / 15% Tint / CSL Trunklid / CSL Diffusor / 6000k HID Headlights and Foglights / BHS Pulleys
[in the works]: Skidrow Plates / Snorkel / Custom rear bumper / Ruf RTurbo
Old 06-25-2003, 10:32 PM
Verndog's Avatar
2003 Toyota Tundra
Smile
Ok...I ran the search...I got one other thread with info on these electronic cuttouts. It looks to me as though this is just a open / close switch for a straight pipe. Not my style....I do not need to piss off the world with a brand new truck....thanx for the help though.
Kevin
My 69 Mach 1 Pics
Factory Options:
Appearance Mods:
Performance Mods:
Old 06-25-2003, 10:57 PM
Jack Burton's Avatar
Dealer : Carson Toyota Scion
2002 Toyota Tundra,
- Other - 1990 4-Runner
Jack Burton is on a distinguished road.
Jack Burton's Photo Albums
Thumbs up Re: Please help with Dual Exhaust Question
3.) I'd go w/Flowmaster Delta Force 50's w/o the resonators. I have a FM Delta Flow 40 and love it. I gained .5 mpg and got a great sounding exhaust. FM says that the 50 is quieter but still has the performance.
Just make sure to stay w/the stock piping diameter of 2.25".
Thanx All
Kevin
Hey Kevin,
1.) You'll probably lose low end torque if you don't use a crossover.
2.) Just go w/the mufflers.
3.) 3.) I'd go w/Flowmaster Delta Force 50's w/o the resonators.
I have a FM Delta Flow 40 single in/dual outs and love it.
I gained .5 mpg and got a great sounding exhaust. FM says that the 50 is quieter but still has the performance. Spintech mufflers are highly regarded on the site, too.
Check out my pics for my FM 40 set up. JB
Old 06-25-2003, 11:10 PM
keiphers's Avatar
If you don't want cutouts I'd go with Spintech.
2003.5 BMW M3
Old 06-25-2003, 11:13 PM
Verndog's Avatar
2003 Toyota Tundra
Thanx Jack...
So if I'm going to run a crossover anyway (sounds like I should), then wouldn't it be smarter to just stay stock up to the muffler, then y out into 2 there? (dual mufflers)
Jeesh...confusing with the options...
Also on your system does your muffler make the 1 into 2 conversion?? I other words do tou have just 1 muffler??
Also...yes I plan to stay with 2.0 or 2 1/4 max pipe dia.
Keipher...can you tell me from 1 to 10 how loud the spintechs are?
Thanx for the help again
My 69 Mach 1 Pics
Factory Options:
Appearance Mods:
Performance Mods:
Old 06-25-2003, 11:26 PM
2002 Toyota Tundra,
Thumbs up Start cheaply...
Thanx Jack...
Thanx for the help again...
Kevin,
I have one muffler that has two outlets that are dumped after the axle. I went w/2.5" in and 2" out. I'd suggest staying w/the stock set up and replace the muffler and maybe the pipe after the 3rd cat/resonator. Check w/V8 Toilet about the Spintech muffler if you're interested in it. You can always add headers if you want more power later. JB
