Old 06-07-2009, 07:42 PM
Dealer : Jon Lancaster Toyota Scion
Last Online: 09-04-2009 12:21 PM
usrauk is on a distinguished road.
usrauk's Photo Albums
Default Blinking 4w hi light
When I press my 4 wheel high button I can hear the actuator that's attached to the transfer case operate but the green light on the button just blinks and it doesn't go into 4 wheel drive, I checked all the electrical conections and cleaned them with electrical contact cleaner, tried tapping the actuator while some one pressed and depressed button, still no luck, is there another actuator on the front differential that I'm missing? my 2001 Tundra has only 48,000 miles, It's an SR5 regular cab and has never been off road. The only trouble before this was both oxygen sensors going bad which I replaced myself since they just failed right after warranty expired, of course!, any ideas of anything else I could look at? I would think if it was the actuator it would not be making any noise when I pres the button, or am I wrong?........Thanks
Old 06-07-2009, 10:55 PM
Highwaylizard's Avatar
Dealer : Butler Toyota Scion
2004 Toyota Tundra Limited DC 4.7 4spd
Last Online: 11-17-2009 06:13 PM
Images: 64
Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all.
Highwaylizard's Photo Albums
Default Re: Blinking 4w hi light
Are you in drive when you do this? My truck will not go into 4 Wheel Hi if it is in Park or Neutral. To go into 4 Wheel Low it has to already be in 4 Wheel Hi and in Neutral.
Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with True Flow foam filter, Mobile 1 in the engine, K&N oil filter, Royal Purple in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires.
testis amotio per pera
150,620miles on the odometer Tundra Fuel Economy Blog
19+ MPG on the Highway at 75 MPH in a DC with a four speed automatic and a bad O2 sensor - not too shabby!
Old 06-08-2009, 12:47 PM
I have tried it in PARK, NEUTRAL, DRIVE and shifting on the fly all the way to 40 MPH which my dealer said it is designed to do. It sometimes made a fairly loud clunking noise when engaging or disengaging which I don't hear any more, so maybe it's something in the transfer case?
Old 06-08-2009, 04:44 PM
Last Online: 09-23-2009 12:20 AM
myardnut will become famous soon enough.
myardnut's Photo Albums
Sounds like the problem I had. It was the actuator. There was later a factory TSB for the fix on these. When I found this problem there was not (I was one of the first to have the problem on my '00 about 6 months after I bought the truck). I was off-roading one day, and went into 4W-Low, and came back to pavement and reset it to 4W-Hi, then back to 2WD. The 4WD-Hi light stayed on blinking, endlessly. It was stuck in 2WD and would not go into 4WD.
At any rate, I took it to a Toyota dealer. It took a while to convince them that it was a problem, and Toyota of Sunnyvale, CA sucks! But in the end they fixed it under warantee, their cost. They had to replace the actuator and rebuild the centerbox (transfer case). God only knows what it would cost to fix out of warantee.
Original owner 4WD 2000 Tundra Ltd, 143k miles
Now with a much improved 2005 front brake system and new rear brake struts.
