Old 06-19-2009, 11:01 PM
ab's Avatar
ab ab is offline
2006 Toyota Tundra DC 4x4 Ltd,
2003 Toyota Sequoia 4x4 Ltd,
- Other - 87 MR2 T-Top,
2005 Toyota Tundra Long bed,
2000 Toyota Tundra AC 4x4 Ltd,
2007 Toyota Tacoma Sport
Last Online: Today 01:14 AM
Images: 5
ab is on a distinguished road.
ab's Photo Albums
Default Seafoam
I have a 06 DC Tundra with 28k on it and just ran two cans of Seafoam thru the intake vacuum line. This produced a huge volume of grey smoke for about ten minutes (my neighbors love me ) After the treatment the truck pulled much lower into the rpms - even down to 1100 before it downshifted and it ran noticeably smoother now on 87 octane than it did before on 92. I was surprised how carboned up the combustion chamber must have been in only 28k. Why would it run so much better with less carbon on the motor?? By the way it wasn't pinging yet. I guess I'll treat it again until it doesn't smoke as much as I assume if it is still smoking that it still has carbon in there. Anyone think that you can use too much Seafoam (other than my wife and neighbors)
Thanks, Mike
[SIZE="1"]00 TUNDRA V8 AC LTD / 03 SEQ LTD / 05 TUNDRA V6 Longbed (2) / 06 TUNDRA DC / 07 TACO DC / 93 Mr2 Turbo / 87 MR2
Old 06-20-2009, 10:02 AM
DJ DJ is offline
Dealer : Fowler Toyota
2001 Toyota Sequoia,
DJ will become famous soon enough. DJ will become famous soon enough.
DJ's Photo Albums
Default Re: Seafoam
The smoking is due to the incomplete combustion of the Seafoam itself as there is not enough oxygen in the combustion chambers to burn it all. The amount of smoke doesn't indicate the amount of carbon being burned away, rather it indicates the rate at which you fog Seafoam through the cylinders.
But don't let the smoke stop you. Seafoam is really good stuff.
Old 06-20-2009, 02:36 PM
ab's Avatar
ab ab is offline
Images: 5
ab's Photo Albums
Default Re: Seafoam
Thanks DJ, nice to see you are still here! Your alignment info has saved me a lot of grief.
Mike.
Old 06-20-2009, 03:21 PM
DJ DJ is offline
DJ's Photo Albums
Default Re: Seafoam
Mike.
Happy to help.
And, I just bought two cans of Seafoam! Nice of you to remind me.
Old 06-20-2009, 05:24 PM
Gutz's Avatar
Diplomacy is dead!!!
Dealer : Fletcher Jones Toyota
2007 Toyota Tundra 5.7 RC/SB
Last Online: Today 01:47 AM
Images: 15
Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything.
Gutz's Photo Albums
Default Re: Seafoam
Now that's funny right thur! Never heard of Seafoam, gonna check it out..
iF57 Tundra Racing Club
Old 06-20-2009, 07:10 PM
DJ DJ is offline
DJ's Photo Albums
Default Re: Seafoam
Seafoam looks, smells, and feels like Coleman Fuel, i.e. it's mostly naptha. It soaks into the carbon deposits and so helps burn them off. Just follow the directions.
Old 06-22-2009, 12:04 PM
ab's Avatar
ab ab is offline
Images: 5
ab's Photo Albums
Default Re: Seafoam
That would explain the smoke while adding the Seafoam but after sucking the can in the vacuum line, letting the engine sit off for five minutes then restarting the engine and reving it up it smokes for at least ten minutes. I would assume that if it were completely decarboned it would not smoke for as long after restarting the engine. I Seafoamed my Sequoia and it didn't smoke much at all even though it has the same engine with more miles but more towing and highway miles. So the question is do I keep retreating the Tundra until I get very little smoke or do I leave it now as it runs smoother and lugs lower?
Thanks, Mike
Old 06-22-2009, 08:34 PM
DJ DJ is offline
DJ's Photo Albums
Default Re: Seafoam
Thanks, Mike
Beats me. Likely it wouldn't hurt anything but your wallet. How 'bout doing it and letting us know? That way if it explodes, it won't hurt us.
That being said, I put one can through the manifold and one can in the gas tank. The smoke quit fairly quickly and the idle is now quite smooth again. I'll keep using it, perhaps a bit more often.
