Re: O2 sensor
From down below. It takes a little finagling, but once you get the socket
on it you should be fine. As people have mentioned, use a good lube
spray on it like PB Blaster and let it set for a while. I also recommend
starting the truck and letting it warm up a little. Not much, mayber a minute.
It doesn't take much to warm up and you don't want it red hot anyway
for obvious reasons. If you're lucky, you'll find the biggest PITA part is disconnecting
the electrical connector. Good luck.
John
The fools, the fools the fools! They have left us
our Fenian dead, and while Ireland holds these
graves, Ireland unfree shall never be at peace!
Padraig Mac Piarais (Patrick Pearse)
