Re: truck problems after ATF flush
First, check the levels while the vehicle is in D. Have someone behind the wheels with the tranny in D and then you should check the fluid level, it should be between H and L.
Second, did you keep the surface clean while dropping the pan and all the stuff u did while the pan was dropped. Cleanliness is a very MUST. U didn't monkey with the soleniods or valve body right. Dropped and cleaned and put it back, right.
Third, always clear all the mappings from the ECM. Disconnect battery for entire night, it will make the ECM know there is better soup in there and that it has to relearn the shift patterns!!!
