I have about 45,000 on my TRD supercharger (2000 Tundra) and all seems to be going well. I have had some leakage of the silicone grease but a Toyota Bulletin notes its not a problem. The unit is not serviceable. Anyone out there have any high mileage superchargers with any problems?
thanks
rg
thanks
rg
What are they saying is not service-able? If its the oil inside you can change it out by pulling the plug on the right-hand side, taking a syringe (only way) unless you take the supercharger completely off the truck. Then take throttle body off, all the 10.9 grade flange bolts, the top plenum off, then pulling the snout, etc.
If you say yours has leaked some , find out how much the supercharger snout holds.
03' Access Cab Toyota Tundra V-8 4.7L, 4x4
305/70/16 BFG Muds on 4" B/S Wheelers' Offroad Steel Rims
Donahoe Racing Coilovers (cranked 2.5")
Total Chaos Upper Control Arms and Rack Bushings.
ORS upper mount shock hoop kit / FOX Racing 2.0" Reservoir 11" travel shocks w/ Deaver G57 10 pack rear springs
ARB Sahara Bumper with Fog Light Kit and KC SlimLites in Front
Your problem is that TRD doesn't make a supercharger for the 4.7 engine.
I use and talk about, but don't sell Amsoil.
2006 Tundra replaced a
98 Dakota 3.9 automatic, long bed.
Retired with broken A/C, July 2008.
623,000 miles.
On original engine and transmission.
+Everybody knows something you don't know.
+Truth does not need to be 'balanced' and it ain't caused by voting or consensus or polls or yelling louder or silencing someone.
+Artists prove truth can be in forms you don't understand.
TRD hasn't made a SC for the 4.7 since the motor switched over to VVTi and they changed the catalytic converter over to a 2 stage and had to add an air injection pump at the plenum. They did make them for the 4.7 up through 2003 (or maybe 2004), you can still find them online, and yes, if you know the right people they can be serviced.
That kinda explains it, doesn't it.
Thanks, Chris.
The cost of supercharging will buy me a lot of petrol, and since it won't improve my MPG I guess I won't be going that route.
623,000 miles.
Thanks, Chris.
If you S/C, you'll also have to start running Premium fuel instead of Regular. That will add a few more bucks to each fill-up.
