Radiator flush
+ Reply to Thread
Results 1 to 8 of 8
Thread: Radiator flush
  1. #1
    Junior Member Al300ex is on a distinguished road. Al300ex's Avatar
    Join Date
    Dec 2002
    Location
    Raleigh, NC
    Age
    36
    Posts
    91
    Liked
    0 times
    Rep Power
    11
    Default Radiator flush
    I cant find the How To in the Garage on flushing the radiator or a complete cooling system flush?? Can someone give me a link? Thanks alot, Alex
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter DaveS is a splendid one to behold. DaveS is a splendid one to behold. DaveS is a splendid one to behold. DaveS is a splendid one to behold. DaveS is a splendid one to behold. DaveS is a splendid one to behold. DaveS is a splendid one to behold. DaveS is a splendid one to behold. DaveS is a splendid one to behold. DaveS is a splendid one to behold. DaveS's Avatar
    Join Date
    Apr 2001
    Location
    Albuquerque, NM
    Posts
    486
    Liked
    1 times
    Rep Power
    19
    Here's the link:
    HOW TO: Coolant Change
    2001 Silver Sky Metallic 4x2 SR5 V8 Access Cab TRD | JBA Titanium Ceramic Coated Headers | Ivan Stewart Aero Kit | Ivan Stewart Graphics and Plaque | ABS | Auto Dimming Temp/Compass Mirror | Toyota Chrome Tube Steps | Toyota UTR Bed Liner | Hidden Hitch receiver w/ DrawTite Wiring | Toyota VIP 3000 Security System | TRD Floor Mats | Alpine CDA-9811 HU | Sirius Sportster Satellite Radio | Polk Audio DB6500 Components (Front) | Polk Audio DB675 Coaxials (Rear) | Alpine MRP-F450 Amp. | JL Audio Stealthbox | JL Audio 250/1 Amp. | Total Chaos Steering Rack Bushings | Hellwig Rear Anti-Sway Bar w/ Greaseable Bushing Mod | Daystar Front Urethane Bushing Kit w/ Greaseable Bushing Mod | Optima 34R Battery | Russell Stainless Steel Brake Lines | Brembo rotors | OSRAM SilverStar Headlights | Sylvania SilverStar Fog Lights | 5 Michelin LTX M/S Tires and Extra Alloy Wheel for 5 Wheel Rotation | Wheel and Spare Tire Locks | Synthetic Fluids
  4. #3
    Assistant Administrator nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    60
    Posts
    6,437
    Liked
    11 times
    Rep Power
    1671
    DaveS
    Thanks
    ~Glenn
  5. #4
    Join Date
    Dec 2002
    Location
    Raleigh, NC
    Age
    36
    Posts
    91
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    There it is
    Thanks, Alex
  6. #5
    Supporter Trouthead is on a distinguished road.
    Join Date
    Feb 2002
    Location
    Wyoming
    Posts
    151
    Liked
    0 times
    Rep Power
    12
    Default What is Toyota Longlife?????
    Is Toyota Longlife DEXCOOL or an equivelant???? Can Havoline or Prestone long life (Dexcool ??) be used. What do the dealers usually use????
  7. #6
    KLS
    KLS is offline
    Supercharged Member KLS is on the right track. KLS's Avatar
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,520
    Liked
    1 times
    Rep Power
    15
    Default Re: What is Toyota Longlife?????
    Not Dexcool. I'd use standard green antifreeze if I didn't use Toyota's special pink stuff. I don't know the real life of Toyota's stuff. If you use green, flush and add new antifreeze every two years.
    The way to check the corrosion inhibitor level in most antifreezes is to test the pH...paper pH test strips work OK and the level should be about 8.5 to 10. Toyota's antifreeze, and maybe some other Japanese brands, is good at about pH 7.
    Ken
    You get what you inspect
    Not what you expect.
    Gibson exhaust system
    Hellwig Rear Antisway Bar
  8. #7
    Junior Member Gilley is on a distinguished road. Gilley's Avatar
    Join Date
    Jan 2003
    Location
    Orlando, FL
    Age
    43
    Posts
    491
    Liked
    0 times
    Rep Power
    11
    How about something like Engine Ice which is premixed. But it's about $16 -$17 a gallon.
  9. #8
    KLS
    KLS is offline
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,520
    Liked
    1 times
    Rep Power
    15
    Sounds like a waste of money. Why not use any standard propylene glycol AF for the safety aspects? Here's what Engine-Ice says, "Newer model street automobiles are equipped with a massive amount of electronic and computerization equipment to keep your car operating at what the manufacturer wants the motor to operate at. One analogy we use is, and we agree it's a bit simplistic, is that even if you filled your radiator with ice cubes, the computer system would hold the thermostat and monitoring equipment until it reaches it's pre-programmed operating temperature. Bottom line is, you'll probably only reduce the temperature by a couple of degrees."
    http://www.engineice.cc/auto.html
    Ken
Posting Permissions
  • You may not post replies
  • You may not edit your posts
