Re: Hard shift fom 2nd to 3rd
The ECM will hold the revs higher under colder outside temps to reduce emissions until the engine is fully warmed up. That way the cats are able to light of the richer AF ratios better and get up to optimal temps faster.
I agree it's a bit annoying, but this is the price to pay for having all the hp/tq on tap while conforming to tighter federal emissions standards.
As a side note, you could try disconnecting the battery for a few minutes, resetting the ECM baseline parameters. This might make things a little more "normal" in terms of all around shift response.
