This is a discussion thread titled "** Real Story on TRD S/C!! **", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
  #31 (permalink)
Old 05-09-2002, 03:33 PM
Last Online: 12-31-2005 12:03 PM
toolbox is on a distinguished road.
toolbox's Photo Albums
Negatives:
- expensive to buy (>$3000)
- must use premium gasolone (90+ octane)
- somewhat reduced gas milage at normal throttle
- greatly reduced milage at wide open throttle.
So, if you drive "normally", keeping the motor under 2200 RPM, accelerating gradually, etc... your milage won't drop too much maybe 1 or 2 MPG. Using maximum throttle at lot will use a lot more gas. More wear and tear? Probably not if you don't abuse the extra power. I'm not sure how much strain the stock Tundra drivetrain can handle, but if you "over do it" often, things wear out quicker.
  #32 (permalink)
Old 05-09-2002, 04:25 PM
Last Online: 04-16-2003 05:04 PM
taco is on a distinguished road.
taco's Photo Albums
I called trd 3 weeks ago and they said an increase of 100 hp and they will be providing a chip to take care of the fuel timing issues.My biggest concern would be the diffs and the tranny, I have no doubt the engine could handle it.If you drive normally you probably won't be using the s/c at all cause it only kicks in when the throttle is applied.My sis and her husband have a gtp grand prix s/c and it flys when the s/c kicks in.
  #33 (permalink)
Old 05-10-2002, 08:31 AM
In the case of the TRD blower, it runs all the time. By this I mean, it is constantly spinning (driven by a belt). This creates an extra load on the motor, thus decreasing milage. On the plus side, the blower uses less HP than it helps create! As I posted a long while ago, the TRD blower is made by Magnuson for TRD. Some of the Magnuson blowers have bypass valves, which vent the blower housing to help prevent the above loss at low RPM. I'm not sure if the TRD one will have this bypass valve.
Put another way, the supercharger is running all the time, it does not get turned "off" and "on". At low RPM (part throttle), it's not doing a lot of work, but at high RPM it's pumping a lot of air (thus enabling you to burn LOTS more fuel) and that equals power.
  #34 (permalink)
Old 05-10-2002, 10:58 AM
SHRIKE's Avatar
Dealer : Elmore Toyota Scion
2006 Toyota Matrix
Last Online: 04-22-2007 05:38 PM
SHRIKE is on a distinguished road.
SHRIKE's Photo Albums
I GUESS (hope) IT'S a MP112 OR a MP90 4TH GENERATION WITH THE Internal Bypass Valve.
(bypass valve virtually eliminates parasitic power loss during part throttle operations)
Is a new air intake kit included or are all the airbox mods now considered mandatory after the install?
  #35 (permalink)
Old 05-10-2002, 04:58 PM
taco's Photo Albums
A bigger blower isn't always better, i read this in a s/c t/c book I have. I will have to look up what it said but I clearly remember it stating that bigger blowers don't necessarily mean more power.I'll look it up and get back to you.I think the v6 is the m62 which is the most common.Later.
  #36 (permalink)
Old 05-13-2002, 03:02 PM
dmtalon's Avatar
2008 Toyota Tundra SR5 Black on Black
Last Online: 01-03-2009 12:10 AM
dmtalon is on a distinguished road.
dmtalon's Photo Albums
This is just general information. A supercharger or Turbocharger will work the same (or very close) in the higher alt. regions.
Assuming it's controled by some sort of wastegate it should still generate 4psi of boost. It will have to work a little harder to do this since the air's thinner, but 4psi of boost is pretty low. I can't imagine there being a noticable drop in HP
Again, this is just general information about how a supercharger/turbocharger works. I have no idea exactly how the TRD supercharger/ECU regulates boost or controls fuel etc..
Dallace
  #37 (permalink)
Old 05-13-2002, 04:37 PM
Stuff's Avatar
Dealer : San Francisco Toyota
- Other - 06 Mitsu Evo 9 MR,
2007 Toyota Tundra RR SR5 CM TRD 4x4
Stuff is on a distinguished road.
Stuff's Photo Albums
  #38 (permalink)
Old 05-13-2002, 07:55 PM
ricqik's Avatar
Last Online: 01-04-2009 08:03 PM
ricqik is on a distinguished road.
ricqik's Photo Albums
There must be a reason why it keeps getting moved back. Anyone know?
Stuffs:
JBA Headers, Costum Exhaust, ASP U/D Pulley, Centric Crossdrilled & Slotted Fr Rotors, LSD, IS Kit, Manik SS Steps, HID Headlights & Fogs, Pacer Tailgate LED Light Bar, Blacked Out Headlight & corners, LED tail lights
Toys:
04 Skeeter ZX250 w/300 Vmax HPDI (79.35gps so far)
05 Polaris Sportsman 700TWIN EFI (rarely ride)
  #39 (permalink)
Old 05-13-2002, 10:17 PM
fyr145's Avatar
Last Online: 11-29-2006 04:33 PM
fyr145 is on a distinguished road.
fyr145's Photo Albums
Default Re: Re: TRD V-8 SuperCharger..
Originally posted by SteveG
"they finally gave us some good news on the TRD V8 Supercharger........this is the REAL STORY from TRD...........
Release date is set as MAY 27th.......will this change?? I give it 2 weeks after that date just to make sure...
Originally posted by Steve G
Ok...........supercharger release date info
It's been moved back until June now.................but we're close...sorry guys.
This shouldnt be that much of a suprise to all of you......Steve did say that it may be a few more weeks. (look above).
Be patient, good things come to those who wait.
  #40 (permalink)
Old 05-14-2002, 06:10 PM
2002 Toyota Tundra
Last Online: 11-23-2005 10:22 PM
pasmith is on a distinguished road.
pasmith's Photo Albums
Talking more waiting
Good things may come to those who wait ... but superchargers are for people who hate to wait.
  #41 (permalink)
Old 05-16-2002, 04:25 AM
fyr145's Avatar
Default Re: more waiting
I'd rather spend the time waiting for it to be done right then be in such a hurry that something gets broken in my Tundra. Time is on our side here....let TRD do their thing and get it right the first time for all of us.
  #42 (permalink)
Old 05-16-2002, 09:00 PM
oz oz is offline
Last Online: 07-28-2002 12:09 PM
oz is on a distinguished road.
oz's Photo Albums
Talking TRD Kazuma supercharger
Well it seems that all of us that have been waiting for the "SC " that are prays have been answered. Look for the SC to be released by late July.
  #43 (permalink)
Old 05-16-2002, 11:15 PM
fyr145's Avatar
Default Re: TRD Kazuma supercharger
hey all,
I have emailed this post to SteveG for confirmation. When i get word or if SteveG writes in, we can get the scoop directly from TRD.
Lets wait to see........
  #44 (permalink)
Old 05-21-2002, 01:24 AM
oz oz is offline
oz's Photo Albums
Talking TRD release date
They (TRD) are working on the part# and price for the SC. The reason the SC has been pushed back so much is that TRD only has one dyno machine and were having a glitch w/the piggyback computer. The piggyback computer is actually and "EBC" Electronic Boost Control. They SC had been done for some time now TRD had 4 prototypes and the EPA had all 4. The upper mangement have SC on there personal Trucks, one is on a Tundra and the other is on a Sequoia. Good things come to those who wait. So I would look for a relase date in late June but most likely mid-July. As for me I have my parts manager put one on order for me
  #45 (permalink)
Old 05-28-2002, 11:59 PM
beckerg's Avatar
Last Online: 02-16-2008 06:14 AM
beckerg is on a distinguished road.
beckerg's Photo Albums
Aaaaaargh!
