This is a discussion thread titled "V8 S/C Idea......", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-01-2003, 12:23 PM
scdtrd's Avatar
Dealer : Lagrange Toyota
Last Online: 07-31-2008 05:34 PM
scdtrd is on a distinguished road.
scdtrd's Photo Albums
Lightbulb V8 S/C Idea......
Ok... running this past yall..... lets see what happens...
Ok, idea #1.
Remove the piggyback ECU and install a boost activated trigger switch that is adjustable for the 9th injector. "T" off the boost port for connection. When you hit a pre set boost level, lets say 3psi or 4psi.. click .. and the 9th injector is flowing.
Simple, cheap, easily done, and you have the stock ECU to boot.
Idea #2.
Find and remove from the piggyback ECU the timing controls for the engine. Put them BACK in the stock ECU and that way, you have the stock timing map, but all the added parameters for the piggyback to monitor for you.....
SCDTRD
The Beast:
1994 Toyota Camry V6 XLE
The Mods:
Front tower Ractive Strut Bar, Whiteline rear AntiSway Bar, Rage Breaker 17.5x7 Rims and Falken Ziex 512 rubber, Limo Tint, Pioneer DEH 7700MP Head Unit, Polk 6x9 rear and Polk 6.5 Front speakers, Tokico struts front and rear, Carbon kevlar brake pads, Cryo treated rotors, ZEX 82021 N2O system, Polished and ported upper and lower intake runners, shift kit, and more to come.....and.... YES... it is a CAMRY....
"Back in the black!"
Old 08-01-2003, 05:22 PM
Dealer : Jim Lynch Toyota
2006 Toyota Tacoma
Last Online: 06-19-2007 10:02 PM
Mudog715 is on a distinguished road.
Mudog715's Photo Albums
Default Re: V8 S/C Idea......
Ok, idea #1.
Idea #2.
SCDTRD
Like many things in life, "it just ain't that simple."
#1: I'm pretty sure the 9th injector is pulse-width modulated like the others -- there is no "on" and "off," but instead many different levels in between. Further, I'm pretty sure the TRD piggyback has to shorten the stock injector pulse widths at the same time to keep it from getting too rich. It's a coordinated effort.
#2: The stock timing map is likely too agressive under boost to use safely without detonation. Some boost retard is probably necessary because of the combination of a supercharger on a relatively high-compression motor (stock SC applications rarely exceed 8:1 cr). However, I'm sure there is more timing to be had than what the TRD piggyback allows... The other problem is the TRD SC adds a "multiple spark" feature to the stock ignition, I imagine just by triggering each igniter several times after the initial firing. I don't think you could lose the TRD timing map without also loosing the "multiple spark" function. I don't know how beneficial it is, but I can't imagine them bothering to add it if it wasn't necessary.
Old 08-01-2003, 07:40 PM
stcj's Avatar
Dealer : Ira Toyota of Danvers
2003 Toyota Tundra
Last Online: 09-19-2008 06:30 AM
stcj is on a distinguished road.
stcj's Photo Albums
I can only comment on the mutiple spark feature, this is a good thing. In by younger days racing cars, I put a MSD unit on my car. Wow, What a big differance. The idle smoothed out, fuel milage increased and obviously HP.
Old 08-01-2003, 08:21 PM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 01-02-2009 07:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
Those were kind of "after my time." The new ignition when I was young was "Transistorized" and breakerless, as well as CDI. What does MSD do to the life of spark plugs? Or is it a racing only application? Since the life of a plug depends on the intensity and duration of the spark, it seems like it would erode the electrodes pretty fast.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 08-01-2003, 08:58 PM
stcj's Avatar
2003 Toyota Tundra
stcj's Photo Albums
It did cause the plugs to wear out quicker, but at that time I didn't care.
Old 08-01-2003, 09:17 PM
2006 Toyota Tacoma
My buddy runs a MSD 6 on his Jeep CJ with a carb'ed AMC 360 V8 and it makes a noticable improvement on that motor.
Modern engines with tightly controlled A/F ratios and factory "high energy" ignitions, operated at "reasonable" speeds don't seem to benefit as much from the aftermarket ignitions. One of the magazines was following a shop buildup of a F350 with the EFI 460 (Ford TFI-IV ignition) and found no measurable power increases with MSD, Crane or Jacobs on that motor vs. the stock ignition. Perhaps at higher RPM's (above 5,000) the aftermarket systems have an advantage.
Old 08-01-2003, 09:45 PM
stcj's Avatar
2003 Toyota Tundra
stcj's Photo Albums
Modern engines with tightly controlled A/F ratios and factory "high energy" ignitions, operated at "reasonable" speeds don't seem to benefit as much from the aftermarket ignitions. One of the magazines was following a shop buildup of a F350 with the EFI 460 (Ford TFI-IV ignition) and found no measurable power increases with MSD, Crane or Jacobs on that motor vs. the stock ignition. Perhaps at higher RPM's (above 5,000) the aftermarket systems have an advantage. [/b][/quote]
I agree with you. Modern day engine management is far supirior to vintage stuff. The two cars I put ignition enhancers on was a '70 Olds Cutlass (not a 442) with a 455ci. The other car is a '69 GTO conv with a 400, which I still have. It has the MDS-6AL. That means it has rubber mounting grommets and changable RPM limitting chips. I used this MSD unit, because the GTO is a 4spd and has Nitrous Oxide. If I miss a shift
Bookmarks
