Broken teeth, front differential
+ Reply to Thread
Results 1 to 2 of 2
Thread: Broken teeth, front differential
  1. #1
    Rookie bobshem is on a distinguished road.
    Join Date
    Oct 2002
    Location
    Anchorage, AK
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default Broken teeth, front differential
    My 2002 Tundra (V8, auto, 4x4) has a trashed front differential. The vehicle has only 77K miles and the differential gear lube had been changed twice during that time with Amsoil Severe Gear lube.
    I can't recall anything happening that could have broken gear teeth but that's what my mechanic found.
    I heard some clunking one day. A few days later I heard a fluttering that indicated that the clunks weren't just a fluke.
    Now I need a $1500 rebuild.
    What could have caused this type of failure? My mechanic is surprised as he believes the front differentials on Tundras to be "bullet proof". The fluid was full and the seals were perfect. He's stumped as to the cause of the failure.
    Any ideas? Thanks in advance.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Just a Herbicidal maniac. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal's Avatar
    Join Date
    Aug 2000
    Location
    Roseville, CA.
    Age
    50
    Posts
    2,028
    Liked
    65 times
    Images
    385
    Rep Power
    5341
    Default Re: Broken teeth, front differential
    I grenaded my front diff about 6 years ago on an off-road trail. I did not have a locker of any kind and the right rear tire was slipping and so was the left front, I backed up slightly (on an off-camber hill) gave it some gas...the tires started slipping and spinning and suddenly the left front grabbed traction and KERWHAM! Sounded almost like a gunshot. The spider gears in the front diff blew up. I still have a small baggie in my glove box with all the busted teeth in it as a reminder. I was fortunate to have the front diff replaced under warranty. Several years later, I installed an RCD lift along with 35's. I regeared to 4.88's, but before putting the new gears in, I had them cryo'd for extra strength. Someday I may put an ARB air locker up front and bye, bye spider gears! They are the weak link and are not bullet proof. On the 1st gen Tundra's they are basically gears from a Tacoma. Not strong enough for our heavier, v8 trucks.
    Back to your truck, could you have been engaged in 4wd and turned tightly on pavement? That would have bound up the front end and potentially broken some teeth. Or like my situation, spun the front tires and then suddenly have one of them 'grab'? If one tire spins like crazy and suddenly stops, that could damage the teeth in the spider gears as all that rotating mass grinds to a halt. Just my .02. I'm sorry that happened to you.
    *** 2007 Black Tundra CrewMax 5.7 liter SR5 4x4 with TRD and tow packages. Old Man Emu 3/1 complete lift with Toyo Open Country M/T's - 285x75x18's. Hypertech speedo recalibrator. Ultra Motorsports 18" black rims with silver accents. N-Fab 6-step, wheel to wheel black nerf bars. G-Tek radiator air-dam and door sill protectors. Arma Coatings spray in bedliner and bumpers by On The Road Trucks in Rocklin, CA. De-badged. Black grill surround. RBP black exhaust tip. Air Lift 5000 air bags with WirelessOne remote. Amp Research bed step.
    *** 2008 Flint Mica Yaris aka: Vios 'S' sedan. TRD lowering springs, TRD cold air intake, TRD anti-sway bar for the rear, TRD Sportivo rear shocks and front struts. Tinted windows all the way around, Tanabe front shock tower brace, 17" rims - Samurai SC02 Hyper Black. Megan Racing header.
    *** 2009 Salsa Red Corolla 'S' 5-speed manual.Wife's ride. Back windows tinted, but otherwise stock.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
