Has anyone had the low fuel stay on?
+ Reply to Thread
Results 1 to 8 of 8
Thread: Has anyone had the low fuel stay on?
  1. #1
    Rookie jm12075 is on a distinguished road. jm12075's Avatar
    Join Date
    Feb 2003
    Location
    Denver, CO
    Age
    56
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default Has anyone had the low fuel stay on?
    My gas was so low one day that the low fuel light was on. I filled the tank and the light stayed on. It now is always on and won't go off. Has anyone seen this before?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Genthar will become famous soon enough. Genthar will become famous soon enough. Genthar will become famous soon enough. Genthar will become famous soon enough. Genthar will become famous soon enough. Genthar will become famous soon enough. Genthar's Avatar
    Join Date
    Jun 2002
    Location
    Escondido, CA
    Posts
    997
    Liked
    0 times
    Rep Power
    13
    Might try a big bump or two and see if that helps .
    Seriously, it sounds like a stuck float on your sending unit. Not sure how you could easily fix it.
    Genthar
    Teamwest Coilovers, Camburg Upper A arms, Daystar Steering Rack Bushings, Total Chaos Diff Drop spacer, JBA Headers, Y-Pipe, and EVOL exhaust, Dynabead balancing media.
  4. #3
    Junior Member filhiol is on a distinguished road.
    Join Date
    Jan 2003
    Location
    pearl river, la
    Age
    76
    Posts
    56
    Liked
    0 times
    Rep Power
    11
    If the gas guage read full after you filled it up I don't think it could be a stuck float. If you don't have warranty and want to check it out yourself I would disconnect the negative cable on the battery, wait several minutes and reconnect it. If that doesn't work wait until the guage shows empty and refill the tank one more time and see what happens. You might also want to check and see if there is a blown fuse the the fuse box.
  5. #4
    Join Date
    Feb 2003
    Location
    Denver, CO
    Age
    56
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks, I'll give the battery cable a try. I have been over some rough dirt roads to try and free it if it was stuck, but no good.
  6. #5
    Join Date
    Feb 2003
    Location
    Denver, CO
    Age
    56
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    OK, I tried the negative battery cable and it had no effect. What fixed it was letting the fuel tank get low enought to trip the low fuel light. That seemed to be the trick. Thanks for all your help.
  7. #6
    Rookie tm111 is on a distinguished road.
    Join Date
    Apr 2003
    Location
    VT
    Posts
    18
    Liked
    0 times
    Rep Power
    0
    Default Re: Has anyone had the low fuel stay on?
    Haven't seen this, but it raises a question I have...When does the light come on for the rest of you? I recently thought my tank was going dry and no light..guage read dead on E, no light. So I filled it and it only took 21 gallons. The light has worked before. Any insight?
    Thanks
  8. #7
    Supporter Alan is on a distinguished road.
    Join Date
    Feb 2002
    Location
    Orange County
    Posts
    141
    Liked
    0 times
    Rep Power
    12
    Unhappy Tundra Fuel Dump Option
    My warning light comes on with around 4 gallons left; seems to be the norm.
    I did have an occurrence recently where I watched in horror at a stoplight, while my fuel gauge needle sank to almost empty, right before my eyes. My tank was about full and the truck was running fine. Within a few blocks it popped back up to the correct level and I’ve had no problems since. So jm12075, you are not alone concerning strange goings on in your tank.
    Stay shiny,
  9. #8
    Join Date
    Feb 2003
    Location
    Denver, CO
    Age
    56
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    What was really wierd to watch was, while the light was on, and the tank went low enough, the fuel light went off. I am curious to see if will work correctly when the tank gets low again. We'll see.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
