Originally posted by smokedog1604
I recently had a custom dual exhaust put on my V8 Tundra. It's not a true dual, it has a Magnaflow muffler with one inlet and two exits. The guy that installed it said he usually removed the OEM resonator so I said ok. My truck has a good sound under idle and wide open throttle. However, there is to much noise at about 55-65 mph under load with the engine turning about 2000 rpm.
I realize with that muffler there will be a large increase in sound, but would having the resonator eliminate some of the noise so that I still get that mean V8 sound but during crusing conditions it be about half as loud.
All of yall, that have put an exhaust (flowmaster/magnaflow) on yours, did you keep the resonator. I don't really care about performance that v8 has power to spare.
Hey smokedog1604,
I have a 3rd cat instead of the resonator you're talking about. I had to keep it for smog testing here in Kali. I believe you'd like the exhaust sound better if you went back w/a resonator. I have a FM 40 2.5" single in/dual 2.0" outs set up like yours and don't mind the freeway cruising sound. It sounds pretty mean when I step on it.
Check out my pics for a couple of shots of my set up.
What size of pipe diameter did you go with on the muffler's in/outs ?
I'm actually switching back to a single in/out Spin Tech muffler soon. I want more of a "sleeper" sounding truck now. I'm also trying for more torque in the low end rpms. JB
