Fyi
Just wanted to let everybody know that Toyota is replacing my P/S pump under warranty. Problem is that when I'm turning to the right or left very slowly (such as going around a corner) I get a rubbing-grinding-whining type noise. Had to order the part so it won't be installed till next week. Hope it fixes the problem but if not it's a freebie. Tech said he knows of no TSB on the pumps just in case any of you are having the same symptoms.
02-SR5/Silver Sky Metallic
Aftermarket Add-On---W/H Sunroof, Retrax Bed Cover, Line-X, Kleen Wheels, Hellwig Rear Sway Bar, Lund Hood Deflector,Weathertech Weatherflectors, Sylvania SilverStar Headlights, Whelen Strobe Lights,Hidden Hitch, Snakeeyes Back-up Camera, Under Cab Lights,VW Sidemarkers, UnderBed Rail Lights, Sirius Satellite
Toyota Add-On---Homelink,Power Antenna,Painted Mirror Covers,Auto Dimming Mirror,RS3000 Upgrade,Rear Door Sill Protectors,TRD Exhaust
MODS---Rear Seat,Map Light
