This is a discussion thread titled "Auto transmission questions", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-22-2003, 04:03 AM
Dealer : Mark Toyota
2002 Toyota Tundra
Last Online: 09-12-2006 05:25 AM
Laubypt is on a distinguished road.
Laubypt's Photo Albums
Default Auto transmission questions
I have a 2002 Tundra V-8 Auto transmission. I had it in to the dealership for service and they suggested that the transmission fluid be changed along with the other service (15000 mile). This was done. When checking over my receipt later I noticed that 6 units of transmission fluid were listed. I looked in the owners manual and it list the transmission capacity at 2.1 quarts for a drain and refill(which didn't seem like it would be enough) Is the owners manual right ????I then decided to check the level and there are no instructions in the owners manual ( prior vehicles had to be started put in each gear ending in neutral or some in park) There is a transmission dipstick but no directions. I did call Toyotas 800 number and talked to a service rep who stated that there was no need to check it if its not listed in the owners manual and that it would be checked with the 30,000 mile service. Service rep looked in manual. They suggested to I ask my dealer. I would like to know the procedure for checking the transmission level and if the manual is right on the capacity of the transmission before I see the dealer again. If the 6 units of transmission fluid were pints they didn't put enough in and if they were quarts its overfilled and I was overcharged. In either case if the manual is right Iam going to be upset.
Old 08-22-2003, 04:47 AM
toyotafool's Avatar
Dealer : Marion Toyota
2000 Toyota Tundra,
2000 Toyota Camry-Solara Solara,
2000 Toyota Celica Celica GTS,
2000 Toyota Corolla corolla S,
- Other - 1993 Previa XLT 4x
Last Online: 10-16-2008 03:43 PM
toyotafool is on a distinguished road.
toyotafool's Photo Albums
don't know the answer but I did think 6 pints was 3 quarts.. at least back in the dark ages when I went to school... if it is ltrs... you are overfull also...don't guess they drained the torque converter do you?? I would talk to the service manager and/or the parts man...
Good luck
John
Old 08-22-2003, 07:27 AM
Dealer : Lake Charles Toyota
2001 Toyota Sequoia
Last Online: 12-16-2008 10:44 PM
doctormdds is on a distinguished road.
doctormdds's Photo Albums
Laubypt,
I don't know about your Tundra but my 2001 Sequoia's drain and fill of the ATF is 4 qts which is NOT what is listed in the manual. There have been lengthy discussions on this topic. Do a search and you should find plenty of information on the drain and fill capacity as well as the proper procedure for checking the fluid. It's frustrating as this should be a simple issue and the data in the manual is WRONG. Toyota seems to have the attitude that checking the level of the ATF is not a do it yourself project. They certainly feel the dealer should be the only one to change the fluid whereas in reality changing the ATF is easier than changing the oil. By the way, the first and only enging oil change at the dealership resulted in them putting 8 qts of oil in the engine. Since them, I've always done it myself.
Old 08-22-2003, 10:02 AM
ricqik's Avatar
Last Online: 01-04-2009 08:03 PM
ricqik is on a distinguished road.
ricqik's Photo Albums
When I had my tranny replaced they added 6qt. I thought it took more than 6qt aomething like 9qt. I questioned the dealer about it and they said 6qt was correct. This is from a dry fill for an new tranny.
Stuffs:
JBA Headers, Costum Exhaust, ASP U/D Pulley, Centric Crossdrilled & Slotted Fr Rotors, LSD, IS Kit, Manik SS Steps, HID Headlights & Fogs, Pacer Tailgate LED Light Bar, Blacked Out Headlight & corners, LED tail lights
Toys:
04 Skeeter ZX250 w/300 Vmax HPDI (79.35gps so far)
05 Polaris Sportsman 700TWIN EFI (rarely ride)
Old 08-22-2003, 12:42 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
The manual is wrong. Draining and refilling the sump takes about 4 quarts. The complete transmission, including the torque converter and cooler and lines requires about 15 quarts.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 08-22-2003, 02:05 PM
Buzzard's Avatar
Dealer : Gulf Coast Toyota
2006 Toyota 4Runner
Last Online: 11-25-2008 05:44 PM
Buzzard is on a distinguished road.
Buzzard's Photo Albums
Its my understanding that over filling a trans is not good. I would be upset if they took out 4 quarts (I drained and filled mine at about 8K and thats what was came out of mine,4 quarts ) and put 6 back in. ---Buzz
Old 08-22-2003, 02:29 PM
Dealer : Carson Toyota Scion
Last Online: 12-11-2008 11:55 PM
Alan is on a distinguished road.
Alan's Photo Albums
Question Directions for the dipstick?
Laubypt - So what was the level on the dipstick? There're no directions, man...just pull it out and see where the level is in relation to the full and empty notches. I believe there are notches if you're checking it cold and notches if you're checking it hot.
Old 08-22-2003, 02:40 PM
Buzzard's Avatar
2006 Toyota 4Runner
The dipstick has a "hot" and "cool" section. Havent read anything in the Toyota Manual but every vehicle I have ever owned said to check it "HOT" and "IN" gear. Should be within the little notched out spots for "hot"---Thats been my experience--If they drained and added 6 quarts--- I believe thats way to much---Buzz
Old 08-22-2003, 08:22 PM
dupont24's Avatar
Dealer : Bennett Toyota
2003 Toyota Tundra
Last Online: 11-09-2007 07:31 PM
dupont24 is on a distinguished road.
dupont24's Photo Albums
Check it hot and in PARK. They may have charged for 6 and only used 4. We use menu pricing where I work, so sometimes you get alil more fluid charged out, but it really doesn't cost extra, just makes it so the svc is the same for every vehicle.
Old 08-22-2003, 08:58 PM
Buzzard's Avatar
2006 Toyota 4Runner
I think your right --in park, makes more sense. Fords use to tell you how to do it on the dipstick. You do it with the engine running of shut off? --Buzz
Old 08-22-2003, 10:50 PM
2002 Toyota Tundra
The service dept advised to check it with the motor running and the transmission in park. Thanks for the help.
Old 08-23-2003, 01:12 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 01-02-2009 07:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
I don't know about the new ones, but if you have a 2000 the dipstick doesn't go back in very easy unless you work down the sharp burrs on the end of it. I got mine about halfway in and it got stuck. When I pulled it back out, it had some metal shavings on it where it had cut into the dipstick tube. I think I've heard of others having the same problem. It helps if you put it back in exactly the same as it came out and don't rotate it from the original position.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 08-23-2003, 10:10 PM
Brian M's Avatar
Dealer : Sand Dollar Toyota Scion
2003 Toyota Sequoia
Last Online: 07-17-2008 08:55 PM
Brian M is on a distinguished road.
Send a message via AIM to Brian M Send a message via Yahoo to Brian M Brian M's Photo Albums
Buzz,
Checking it in gear would probably work but you would need to wear your track shoes to keep up with the rolling truck.
2003 Sequoia SR5 - Phantom Gray
2006 F150 SuperCrew Lariat - Black/Gold
Old 08-23-2003, 10:29 PM
Buzzard's Avatar
2006 Toyota 4Runner
Originally posted by Brian M
Buzz,
hahahaha--dont know where the gear thing came from. If you do it my way SET THE BRAKE!!!! ---Buzz
Bookmarks
