Old 08-23-2003, 03:21 PM
Last Online: 05-27-2006 11:36 AM
RDU Tundra is on a distinguished road.
RDU Tundra's Photo Albums
Default General lubrication
I want to start doing the general lube work on my 2WD myself, just to make sure everything is done regularly.
Where on this site can I find information on where all the grease fittings are? I have done a search and only found 4WD prop shaft information.
Old 08-23-2003, 03:44 PM
Dealer : Acton Toyota of Littleton
2006 Toyota Avalon,
2003 Toyota Highlander,
2007 Toyota Corolla
Last Online: 09-08-2008 07:16 AM
MMitsock is on a distinguished road.
MMitsock's Photo Albums
As far as I know there are no grease fittings on 2WD Tundras and they are only on the drive shaft of 4WD Tundras.
Old 08-23-2003, 05:54 PM
Buzzard's Avatar
Dealer : Gulf Coast Toyota
2006 Toyota 4Runner
Last Online: 11-25-2008 05:44 PM
Buzzard is on a distinguished road.
Buzzard's Photo Albums
Thats weird isnt it----no grease fittings--Everything needs a little grease every once in a while--Buzz
Old 12-29-2004, 05:13 PM
Last Online: 07-20-2005 12:34 PM
chrisstankevitz is on a distinguished road.
chrisstankevitz's Photo Albums
Yeah, what's the story? 2WD tundra never needs anything greased?
What does a $20 "oil and lube" get you if you take your tundra in?
Old 12-29-2004, 06:13 PM
Genthar's Avatar
Last Online: 11-05-2009 09:51 PM
Genthar is on a distinguished road.
Genthar's Photo Albums
My old Eclipse was the same way. "Sealed Chassis" they call it. Supposedly never needs lubing.
Of course my old '66 Mustang's rear diff was supposed to have "lifetime" fluid in it too...when I "inherited" it (it was the family hand-me-down) I went to change the fluid, and it was about as viscous as gasoline....
Genthar
Old 12-29-2004, 09:46 PM
Muleskinner's Avatar
Dealer : I-10 Toyota Scion
2004 Toyota Tundra
Last Online: 03-15-2008 04:37 AM
Muleskinner is on a distinguished road.
Muleskinner's Photo Albums
It's called "Preplanned obsolecence." The automotive manufactures started this trend in the 70's.
Yes the new type lubricant the factory uses in the steering, driveline and suspension components is good, but lasting for a lifetime is stretching it a bit.
Hopefully some aftermarket manufacturer will make 'lubeable" Ujoints, tie rod ends and other "Non lubable" items available for replacement parts. But if the manufacture's claims are correct, we should never need to replace these items anyway!
04 DOUBLE CAB SR5 DESERTSAND MICA, CUSTOM FABRICATED Y PIPE, JET PERFORMANCE STAGE TWO ECU REMAP, RACOR REMOTE A/T FILTER, ROADMASTER RAS (REAR)
Old 12-29-2004, 10:00 PM
Sanosuke's Avatar
Dealer : High River Toyota
2007 Toyota Tundra SR5 w/4x4
Last Online: 11-17-2009 05:50 PM
Images: 8
Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor.
Send a message via ICQ to Sanosuke Send a message via AIM to Sanosuke Send a message via MSN to Sanosuke Send a message via Yahoo to Sanosuke Sanosuke's Photo Albums
Talking
Maytag Durablity anyone? No calls to the lonely repairman!
The Gordon Jump version of the Maytag commericals rocked.
Sanosuke!
