Old 09-04-2003, 11:25 AM
ZIGGY454's Avatar
Dealer : Rockingham Toyota
2002 Toyota Tundra
Last Online: 11-16-2009 09:22 AM
ZIGGY454 is on a distinguished road.
ZIGGY454's Photo Albums
Default Valve Chatter Upon Startup; Due To Defective Check Valve In Mobile 1 Oil Filter !!
ALLRIGHT BOY'S; I recently changed my engine oil a week or so ago and noticed that after I did this I would hear valve chatter upon startup, only after it sat all night or all day at work. Now just so you know I used the same parts and oil that was in the engine allready, which was Mobil 1 5w-30 sythetic oil and a Mobil 1 oil filter M-102. So, last night I finally said enough allready and pulled out the M-102 Oil Filter, well the check valve had a little bubble or deformaty on the inner seal below the metal threaded endplate. Now, as I stated before the previous M-102 filter did not do this and I had NO Valve Chatter upon startup. So, needless to say I am going to take my sales recipt back to Autozone and get my money back on this filter, I also am pretty dissappointed that a filter that costs $12 Bucks a pop has this problem !!!!! So this brings me to this subject; I have been doing some extensive reshearch on allternative filters for these engines as you can see from all of my previous posts on this subject. So I installed the Purolator Pure One Micronic Filter Part# PL-30001 last night and everthing so far is checking out great. The oil pressure is identical as before. both in range, RPM wise and in pressures. And I have yet to hear Valve Chatter upon startup !!! I plan to monitor this experiment closely and will keep you guy's posted !!!
PS: The best part of this gig is that I stongly believe that I am getting a superior filter in both design and efficiency to the TRD Filter# 00602-90915-007 and the Toyota Filter#90915-YZZ-B5 and to boot getting this Purolator Micronic for $6 BUCKS A POP !!!!!!
FEED BACK WELCOME GUY'S !!!!!!!
Old 09-04-2003, 11:56 AM
scdtrd's Avatar
Dealer : Lagrange Toyota
Last Online: 02-09-2009 04:48 PM
scdtrd is on a distinguished road.
scdtrd's Photo Albums
I agree... I use ONLY The Pure-1 and Amzoil 20W50 Race blend...
All I need do is check oil every 5k or so.. and let it ride!
SCDTRD
The Beast:
1994 Toyota Camry V6 XLE
The Mods:
Front tower Ractive Strut Bar, Whiteline rear AntiSway Bar, Rage Breaker 17.5x7 Rims and Falken Ziex 512 rubber, Limo Tint, Pioneer DEH 7700MP Head Unit, Polk 6x9 rear and Polk 6.5 Front speakers, Tokico struts front and rear, Carbon kevlar brake pads, Cryo treated rotors, ZEX 82021 N2O system, Polished and ported upper and lower intake runners, shift kit, and more to come.....and.... YES... it is a CAMRY....
"Back in the black!"
Old 09-04-2003, 12:54 PM
ZIGGY454's Avatar
2002 Toyota Tundra
SCTRD; Do you use the Micronic PL-3001 filter, Dont know if it is a good idea to use the 20w- 50 oil though ??? Puts a lot of drag and strain on your oil pump drive. The 4.7 has real tight tollerances between all the bearings, cam lifters. You would be better off running 10w-30 in the cooler months, and mabe 15w-40 in the summer months. I know it can get pretty hot down there in Georgia !! Hey but if its workin for ya let it be !!!
Thanks for the reply !!!!
ZIGGY
Old 09-05-2003, 12:34 PM
scdtrd's Avatar
ZIGGY
I agree... I was worried about it.. but... with a S/C engine and Gawja being as hot as it has been... so far so good. I ran 50W-50 in my Tacoma 3.4L for 126K and it was still solid.. So.. I go with what I know!
The amzoil is "thinner" molecule wise than the fossil stuff anyway and is uniform in size.
SCDTRD
The Beast:
The Mods:
