This is a discussion thread titled "Rear Axle Rust already?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-08-2003, 08:39 AM
tiger's Avatar
Dealer : Beaman Toyota Co.
2005 Toyota Tundra,
2008 Toyota Highlander HV
Last Online: 12-04-2008 06:11 PM
tiger is on a distinguished road.
tiger's Photo Albums
Post Rear Axle Rust already?
Climed under the truck while washing it and noticed alot of rust on the rear axle The weather in this this region is good and I always hose off the salt when it snows maybe 3-4 times a year. It's an 02 model and I never go off-road, only twice, and it was hosed off underneath immediatly afterwards. Does anyone else have this problem? It's not tiny spots, it is very visible. About 30 spots, 1/2 in. in diamater all over the rear axle.
Old 09-08-2003, 09:49 AM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 03:11 PM
DevinSixtySeven is a splendid one to behold. DevinSixtySeven is a splendid one to behold.
yeah...same problem. a coat of POR-15 before winter should prevent further rust, but i'm not sure of the best way to remove the rust that's on there. i'd hate to seal it underneath the paint.
-sean
GFX by FreedomEagle50
Manual Hubs
Old 09-08-2003, 03:06 PM
Dealer : Russel Toyota
Last Online: 03-12-2006 06:51 PM
Stooge is on a distinguished road.
Stooge's Photo Albums
The paint is being constantly chipped off from sand, rocks and rain from the road. Amsoil sells a product called Heavy Duty Metal Protector. It's great as an undercoat, lube and motorcycle chain lube. It drys to a smooth, shiney, waxy finish that does not attract dust and dirt. It's alot tougher than regular paint in the wear department as well. Just watch out for the overspray as it is real hard to remove once dry and stinks real bad when wet!
Old 09-08-2003, 03:11 PM
interesting...can this be used over a coat of POR-15?
-sean
Manual Hubs
Old 09-08-2003, 03:16 PM
Excuse my ignorance, but what is POR-15? Undercoat, paint?
Old 09-08-2003, 04:56 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
I don't consider it to be a problem, but if I did, I'd wirebrush the rust off and paint the whole thing with some Hammerite paint from the hardware store.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 09-08-2003, 09:16 PM
Johnny Law's Avatar
Moderator
Dealer : Haddad Toyota
2005 Toyota Tacoma
Last Online: 01-03-2009 08:29 PM
Johnny Law is on a distinguished road.
Johnny Law's Photo Albums My eBay
POR stands for Paint Over Rust, and it does what it says. Good stuff, will make you pass out from the fumes though.
"Si vis pacem, para bellum"-Vegetius
2005 Tacoma Doublecab TRD Offroad 4X4 shortbed - Modifications - Fog light mod, Debadged, Black Toyota grille emblem, Map Light Mod, DRL mod
Factory Accessories - Tacoma Bedmat, Extra set of D-rings installed in front bed bolts, Extra set of factory tie downs
Optional Options - FilterMag, Fumoto valve, Westin Suregrip running boards w/LED lights, WeatherTech Floorliners, WeatherTech window visor vents, Prestige remote car starter w/keyless entry, SilverStar headlight and turn signal bulbs, Toytek 2" lift, Muth heated signal mirrors, WAAG grille guard (center only, I'm old school), Taillights tinted by JonsTintedTails.com, Anthracite FJ Cruiser wheels w/ 265/75r16 BFGoodrich A/T
Old 09-10-2003, 11:27 PM
Joe's Avatar
Joe Joe is offline
Dealer : Tim Corwin Toyota
Last Online: 12-31-2008 10:15 AM
Joe is on a distinguished road.
Joe's Photo Albums
Originally Posted by hovisimo
i'm with ken, it'd be best to grind off the rust with a wirebrush on a die grinder or angle grinder, it's never a good idea to paint over it. i repaint semitrailers at work and it doesn't matter what kind of coating i use, if i apply it to rust it will rust again. and not stick very well either.
POR15 is a different animal and does an outstanding job relative to painting over rust and rust prevention but it's pricey. http://www.por15.com/
Old 09-10-2003, 11:41 PM
Y2kn1Tun's Avatar
Last Online: 04-27-2008 03:26 AM
Y2kn1Tun is on a distinguished road.
Y2kn1Tun's Photo Albums
Werd... POR-15 is some crazy stuff. Just be sure you don't get any on your skin while your applying it, its nearly impossible to get off.
Old 09-11-2003, 07:33 AM
TampaBayTundra's Avatar
Dealer : Sun Toyota Scion
Last Online: 04-24-2007 07:13 AM
TampaBayTundra is on a distinguished road.
TampaBayTundra's Photo Albums
What about Naval Jelly?
Old 09-11-2003, 09:28 AM
what the hey is "naval jelly", other than a bad joke waiting to happen ?
Manual Hubs
Old 09-11-2003, 10:26 AM
Dealer : Carson Toyota Scion
2003 Toyota Tundra
Last Online: 02-10-2008 03:26 AM
Sweetwater is on a distinguished road.
Sweetwater's Photo Albums
[quote=KLS]I don't consider it to be a problem, but if I did, I'd wirebrush the rust off and paint the whole thing with some Hammerite paint from the hardware store.
Ken,
Where do you find Hammerite? I checked their website and it doesn't show who carries it in the U.S. since its a product of the UK.
Thanks, Joe
Old 09-11-2003, 11:57 AM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
My local hardware store carries Hammerite brand paint in spray cans and pint & quart cans. Check around locally. I've found Hammerite paint to be far superior to Rustoleum. In all cases, remove as much rust as you can, prime well, and paint well. Two coats of primer and two-three coats of enamel work well.
Naval Jelly is a brand of a phosphoric acid product in a gel. When applied to rust (iron oxide) it converts the iron oxide to iron phosphate which is a very good base for paint. It does little or nothing on clear iron/steel. Naval Jelly and similar products do almost nothing on loose rust...scrape and wire brush first.
Ken
Old 09-12-2003, 06:07 PM
http://toyotaoffroad.com/Articles/Rust/Rust.htm
Manual Hubs
Bookmarks
