This is a discussion thread titled "supercharger", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-08-2003, 08:21 PM
Last Online: 09-17-2003 08:19 AM
Timcd46 is on a distinguished road.
Timcd46's Photo Albums
Default supercharger
I had my dealer install the TRD supercharger, and I burn 93 octane gas as they recomend. But on anything close to wide open throttle, I can hear a substantial engine knock (ping). Any help or recomendations. Thanks.
Old 09-09-2003, 11:00 AM
Last Online: 11-20-2004 01:42 AM
delrmx01 is on a distinguished road.
delrmx01's Photo Albums
Might want to do a quick search on this topic..this board has tons of useful information.
As for the ping-- what kind of plugs are you using?
Old 09-10-2003, 10:02 PM
zebra1550's Avatar
Dealer : Performance Toyota Of Lavista
2005 Toyota Tacoma
Last Online: 11-06-2008 08:47 PM
zebra1550 is on a distinguished road.
zebra1550's Photo Albums
Somebody help me if I'm wrong...but I believe the stock fuel pressure regulator runs off of a vacuum line. There is a way to connect a T fitting into a boost line running off the S/C. You then replace the vacuum line going into the FPR with a line running off the T fitting from the boost line. What this does is allow the fuel pressure regulator to flow more fuel at WOT. Its good for a couple extra PSI in the fuel line, and is now the standard setup on the 3.4L TRD S/C. I used to have a S/C Tacoma and remember setting up the FPR this way. My 3.4L S/C never had any problems pinging using this setup and 92 octane fuel. Try doing a search on this info, I beleive someone already posted this fix. It would be worth the try and wouldn't cost or hurt anything.
2005 Toyota Tacoma Double Cab 4X4
Speedway Blue Short Bed w/TRD Off Road Package, 2006 Tundra Wheels with 265/75R16 BFG AT KO's, Python 2-Way Remote Starter, Color Matched Hard Tonneau Cover
Old 09-11-2003, 12:38 PM
scdtrd's Avatar
Dealer : Lagrange Toyota
Last Online: 07-31-2008 05:34 PM
scdtrd is on a distinguished road.
scdtrd's Photo Albums
Check out my photos. I have done exactly what your talking about. It is called "boost port additions" or close to that.. anyway.. you will see!
SCDTRD
The Beast:
1994 Toyota Camry V6 XLE
The Mods:
Front tower Ractive Strut Bar, Whiteline rear AntiSway Bar, Rage Breaker 17.5x7 Rims and Falken Ziex 512 rubber, Limo Tint, Pioneer DEH 7700MP Head Unit, Polk 6x9 rear and Polk 6.5 Front speakers, Tokico struts front and rear, Carbon kevlar brake pads, Cryo treated rotors, ZEX 82021 N2O system, Polished and ported upper and lower intake runners, shift kit, and more to come.....and.... YES... it is a CAMRY....
"Back in the black!"
Old 09-15-2003, 09:35 AM
atv6812's Avatar
Last Online: 10-03-2003 08:14 PM
atv6812 is on a distinguished road.
atv6812's Photo Albums
Default Feedback.
I don't have an answer to your problem with pinging. I think it sounds like detonation. I had a similiar issue with an F150 V8 that always pinged when I went to full throttle while still using 93 octance fuel.
I have a Toyota Tundra 01 (4.7L) currently and was thinking of upgrading to the TRD Supercharger but I've heard that pinging is a problem. Have you seen a substantial increase in HP and torque? As far as driving goes, how does your truck perform as a daily driver? Thanks.
Old 09-15-2003, 02:56 PM
Last Online: 07-02-2007 03:13 AM
larryf is on a distinguished road.
Send a message via AIM to larryf larryf's Photo Albums
Search for my posts on here, and you'll see all my ping woes.
Methanol is my only fixture to major ping. BTW, I hear it a lot more than you do, but I have yet to get a check engine light out of it.
The $110 spark plug solution might work for you.
Larry
Old 09-15-2003, 04:02 PM
TRDKEAU's Avatar
Dealer : Carson Toyota Scion
2006 Toyota 4Runner
Last Online: 07-24-2008 12:36 PM
TRDKEAU is on a distinguished road.
TRDKEAU's Photo Albums
Larry
either Denso iridum ik-22's,24's or NGK V GROOVES. Steve at carson got them for me for 99.00 shipped.
Old 09-16-2003, 09:33 PM
By the way, does anyone else notice that the truck runs better at 3/4 throttle that it does at WOT?
Last night on my way home from work, at a stop sign, I wanted to give a good pull to see if I could make it ping (with my 5% methanol mix) and it broke the tires lose.. It's never done that on dry ground before... It was kinda nice.. I had to peddle it, but I got it going about 3/4 throttle, and it actually ran really nice.. I could feel it pulling the whole time, it didn't lay down at all.
When I make my return trip to the drag strip to re-test the truck with the blower I'll be hard pressed to run it WOT...
At least the track wont lie, I'll know how it runs best after a couple passes.
Larry
Old 09-16-2003, 09:38 PM
scdtrd's Avatar
Larry
Yep... I DO! It is the SAME feeling I get. It runs better the LESS I mash the gas. I geuss mine is in the 1/2 to 3/4 range. Shifts smoother and pulls the whole time. If I go WOT.. then it really dissapoints. Noticed it blowing black smoke out the pipe when it started to stumble. Like all of a sudden, someone put a 5th wheel behind me. That is how I describe it.
SCDTRD
The Beast:
The Mods:
Old 09-16-2003, 09:40 PM
TRDKEAU's Avatar
2006 Toyota 4Runner
Larry
I break my tires constantly at 3/4 and I have 285's and LSD! DITTO on 3/4 performance though. It almost feels that when you go WOT in between powerbands or 1-3rd gear. The ECU is dragging behind, but i guess that is the woes of having force induction. You have to learn how to drive a s/c or turbo different. KNow when you can spool up the fastest. I would like to sit in someones truck who has a unichip piggybacking.
Old 09-16-2003, 09:44 PM
Thats fuel cutoff... The ECU goes into fuel cutoff before the shift. I don't notice it has bad as you describe, but it does stuble a little on shift.
Larry
Old 09-16-2003, 09:47 PM
scdtrd's Avatar
I am almost there! I spoke to Jack today as a matter of fact and it is getting close. I am ON THE LIST. I will make the TRD PIGGYBACK ECU work better as a frisbee or door stop. I believe it is ment for that. I will dyno B4 and After.
I will also post pics and leave a detailed account out here for all to see.
I am not done by a long shot. Just an observation... My O2 went out about a month ago. I was worried... Then, spoke to David (Toyota Tech buddy) and he told me that it makes NO DIFF on the ECU, that it is just running on a fixed fuel map, insted of a dynamic map. Basically, OPEN LOOP vs. CLOSED LOOP. So, ok.
I have done some monitoring, and my mileage has gone UP slightly. From 14.3 to 15.1 on AVG!!! Imagine that?
Hmmmmm...
SCDTRD
The Beast:
The Mods:
Old 09-16-2003, 09:48 PM
Unichip? Just unplug your ECU, and you'll feel what the truck can do.. Just don't expect it to last too long. Toyota of Santa Maria is rebuilding trannys in the Tundra left and right, and this is just the normal trucks. (Mine is the first Supercharged Tundra they've seen). According to TRD, the dead-shift is because they broke tranny's, input shafts, etc during development. Scott, do you make 5psi at 3/4 or is it less? TRD offers a 4psi pulley for $35. (Or free if you b***h about ping enough).
Larry
Old 09-16-2003, 09:51 PM
Hmmmmm...
SCDTRD
I can't.. The only car I've seen 15+ in is my wife's 99 Rav.. We'd get 30 in that. And like a dummy I traded it for a Highlander. Twice the payment and half the milage.
I must be a sucky driver, milage is just something I can't get.
Larry
Old 09-16-2003, 09:54 PM
scdtrd's Avatar
Max is 6PSI, 5 and some change at 3/4 throttle. I know what your referring to on the tranny. SMOKED 2nd clutch pack on my Tacoma when I did all this to it as well. Learned my lesson. I will have the tranny reworked at Level 10 and be able to pump up the volume. You have to look at the whole drive line.
The A340E is a good tranny, just too sloppy in the shifts and too much heat buildup. It WILL toast a clutch pack.
SCDTRD
The Beast:
The Mods:
