This is a discussion thread titled "Rear axle extension?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-09-2003, 11:24 PM
Last Online: 06-28-2004 12:13 AM
RDOGG is on a distinguished road.
RDOGG's Photo Albums
Question Rear axle extension?
I just got my truck back from camburg, and the front is 3.5" wider each side, I was wondering if anybody had done a similar thing with the back? I think it would look a lot better.
Old 09-14-2003, 04:42 PM
mxjeremy's Avatar
Dealer : Gosch Toyota Scion
Last Online: 08-04-2008 06:43 PM
mxjeremy is on a distinguished road.
mxjeremy's Photo Albums
I'm sure you don't have any money left, but your best bet to match the capability of the front would be to get a HD rear axle and a 3 or 4 link setup. People like using ford 9"s, dana 60's, or custom billet rear ends. If you did this, you could probably get a bit wider rear, but you need to run rear glass. Also, with a new axle, you can get your gears, locker, and rear disc brake upgrades all at the same time. Let us know what you think of the kit.
Old 09-14-2003, 04:52 PM
TRDKEAU's Avatar
Dealer : Carson Toyota Scion
2006 Toyota 4Runner
Last Online: 07-24-2008 12:36 PM
TRDKEAU is on a distinguished road.
TRDKEAU's Photo Albums
or a cheaper way would be to run wheel spacers. what kit would you use for your disc conversion? rear sequioas?
Old 09-14-2003, 05:18 PM
mxjeremy's Avatar
I don't like wheel spacers. They provide your tire with more leverage to rip off your wheel studs. You don't need a kit for disc conversion since you will be using a custom axle. Here's what you need, stage II (drum) or III (disc):
http://www.currieenterprises.com/htm...dPackTruck.htm
Old 09-14-2003, 06:01 PM
wes 03's Avatar
Dealer : Durant Toyota
2003 Toyota Tundra
Last Online: 03-06-2008 10:02 AM
wes 03 is on a distinguished road.
Send a message via AIM to wes 03 Send a message via Yahoo to wes 03 wes 03's Photo Albums
my dream would be a 4 link rear with coilovers, ford 9 inch width to match the front, custom 6 lug to match the front, disk brakes, 40 spline axles, spool!
will that work for you? oh ya, i hate wheel spacers, had a friend use them and he ended up replacing his rear disks, calipers, wheel, and brake lines, spacers suck!!
wes
Old 09-14-2003, 11:33 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 03:11 PM
DevinSixtySeven is a splendid one to behold. DevinSixtySeven is a splendid one to behold.
wes
all depends on the quality of the spacers, also gonna depend on the float config of the rear axle, tundras and tacomas are semi-float. anyway, www.aor4x4.com has some beefy spacers, so does www.offroadsolutions.com . also, protrux sells a smaller pumpkin, stronger toyota-like axle for the rear, custom built--it's just the shell, you get to add perches and brakes etc. a d-60 shell is some serious weight and lack of clearance, to be avoided if possible...you can get a nearly equivalent strength from that toyota-based custom axle and crmo shafts, with a full-float conversion so you don't trash a hub and a halfshaft all at once when you break something. there's info on the sas threads about strength, that's why joe is using a d44 rather than a d60 (price, too), and there's more info on pirate4x4.com, doesn't matter if youre crawling or running, it's the same components.
-sean
GFX by FreedomEagle50
Manual Hubs
Bookmarks
