This is a discussion thread titled "Fluid capacities", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-19-2003, 07:16 PM
Last Online: 09-30-2003 02:15 PM
Laps is on a distinguished road.
Laps's Photo Albums
Default Fluid capacities
Can someone post the fluid capacities for the Tundra for the transmission and differentials, thanks.
Old 09-19-2003, 09:29 PM
Ripper's Avatar
Last Online: 09-10-2004 03:36 PM
Ripper is on a distinguished road.
Send a message via Yahoo to Ripper Ripper's Photo Albums
Just happen to have this information on a piece of paper in my pocket because I stopped by the parts store today to pick up enough gear oil to change them all tomorrow.
Front Differential - 4WD
1.2 Quart
75W-90 API GL-5
Transfer Case - 4WD
1.1 Quart
75W-90 API GL-4 or GL-5
Differential - TRD Limited Slip
3.1 Quart
SAE 90 API GL-5 for limited slip
I ended up picking up 6 quarts of Mobil1 75W-90 Synthetic gear oil. I also got a tube of Trans-X Posi-Trac Limited Slip Gear Oil Additive. Never heard of this brand/type before but it was all the store had and it says it meets oem requirements for "most imports". It specifically says to use it with convential or synthetic GL-5 gear oil.
2003 Tundra SR5 Access Cab - Phantom Perl Gray, 4WD TRD
LSD, Tow Package, Front Skidplate, Auto Dim Compass/Temp Review Mirror, Factory Tonneau Cover, PPD Billet TB Cover , GFX Chrome Nerf Bars
Stone Mountain Racing Headers, Modified Stock Y Pipe, Custom Exhaust Pipes, Flowmaster Delta 50 Series, Polished Stainless Tips
Blaupunkt San Jose Head, Delphi XM Satellite Radio, Kenwood KFC-1779ie (Front), Rockford Fosgate FRC 3206 (Rear), Terk XM11 Antenna
Old 09-19-2003, 10:58 PM
Laps's Photo Albums
Thanks for your help! Don't happen to have the capacity for the automatic transmission by chance?
Old 09-20-2003, 12:26 AM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 01-01-2009 05:17 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
14.9 quarts. I bought 16 when I did mine I think. That is for a complete flush, not just emptying what is in the pan.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 09-20-2003, 08:00 PM
Laps's Photo Albums
Is a complete transmission fluid flush something that can be done by a general maintenance type garage? Thanks, Laps.
Old 09-20-2003, 11:35 PM
SATundra's Avatar
YOU can do it. All you need is a 13mm (think thats the size) wrench for transmission drain plug, a pair of pliers to get the cooler hose off, and a 5 gallon bucket, thats it. Sorry and a funnel to add fluid back in.
If you take it to a garage they will tell you they need to have a recycling machine, most dealerships, even quickie oil change places have them now days. I believe places are charging about $70-$100 PLUS you bring your own fluid.
SATundra
MODS:
TIRES:
SUSPENSION:
Old 01-31-2004, 12:13 AM
Invid's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra
Last Online: Yesterday 02:21 AM
Invid is on a distinguished road.
Invid's Photo Albums
I am looking forward to replacing mine come the time but I have a question. I want to use Amsoil in the change but what type do I use? The list on amsoil.com confuses me and damn my luck for losing my Owners Manual.
Old 01-31-2004, 12:39 PM
sequoiasoon's Avatar
Dealer : Competition Toyota Scion of Middle Island
2003 Toyota Sequoia,
- Other - 93 Corolla TOTALLED!
Last Online: Today 03:46 AM
sequoiasoon is on a distinguished road.
sequoiasoon's Photo Albums
Default Ripper
Check your manual for the 2003. I've got a 2003 Sequoia (built April '03) and it lists the following:
Transfer case: GL-4 or GL-5 75W-90 1.3 qt
Front Differential: GL-5 75W-90 1.2 qt
Rear Differential: GL-5 3.9 qt.Synthetic 75W-140 I presume the TRD LSD might be different. (you list SAE90)
Tranny only lists drain and refill but Toyota type T-IV which is NOT compatible with regular dexron II or III
Old 02-02-2004, 06:24 PM
Crazychopstick's Avatar
Dealer : Mitchell Toyota
1997 Toyota 4Runner
Last Online: 09-18-2007 12:40 PM
Crazychopstick is on a distinguished road.
Send a message via AIM to Crazychopstick Crazychopstick's Photo Albums
Where do you disopose of the old transmission fluid?
Is there a recycle place for them?
Old 02-02-2004, 07:16 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Here it's OK to put used ATF in the used motor oil recycle tank. ATF is an oil, after all.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 02-02-2004, 09:25 PM
SATundra's Avatar
Ken
Same here, they let me dump my old tranny fluid in with the oil at the quicky oil change place.
SATundra
MODS:
TIRES:
SUSPENSION:
Old 02-02-2004, 10:20 PM
1997 Toyota 4Runner
Default For a full flush...
Sorry if I'm a slow learner but let me get this straight.
Loosen the transmission drain plug, take off the lower cooler hose and lead the hose in to a 5 gallon bucket that is marked off in quarts.
Then turn on the engine and run untill 2 quarts pump out.
Turn off the engine.
Add 2 quarts through a funnel.
Turn on the engine and run untill 2 more quarts pump out.
Repeat. Correct?
Old 02-03-2004, 12:17 AM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Drain the transmission and replace the plug.
Refill the transmission to the normal level, about 4 quarts.
Disconnect the cooler hose, add a longer length of hose so it reaches a bucket or jug, run the engine briefly to pump out two quarts, stop the engine, add two quarts of new ATF down the transmission dipstick tube, run the engine to pump out two quarts, etc., etc., until you've exchanged another 12 quarts for total of 16 quarts. Put everything back together, check for leaks, and correct the level.
I'd add a Magnefine or SPX Filtran in-line transmission filter (3/8") to the cooler line.
Ken
Old 02-03-2004, 04:05 PM
1997 Toyota 4Runner
Default Just 4 Quarts?
Thanks. At 55,000 miles I think it is time to flush it.
But I called my local Toyota dealership and they said that these "newer" trucks, meaning the Tundras, don't need to be flushed, just replace the oil.
What's that all about. Do they know what they are talking about?
Old 02-03-2004, 05:02 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Compare the color of your present ATF to new ATF. Are the two equally bright red? If your ATF is signficantly darkened or smells scorched, if definately requires a complete flush. Many folks just drain and refill the four quarts from the pan every 10,000 miles or so, and thus keep the ATF freshened. I do a complete flush myself. Because I spend the money for synthetic ATF, I find it cost effective to send a sample to the lab for analysis before I dump it. So far, the synthetic ATF is still good at 30,000 as determined by the lab.
Ken
