This is a discussion thread titled "Fan Roars on Startup", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-23-2003, 11:09 AM
Dealer : Moose Jaw Toyota
2003 Toyota Tundra White Regular Cab,
1995 Toyota Tercel 1994 base tercel
Last Online: 01-06-2009 10:23 AM
file014 may have some regrets.
file014's Photo Albums
Default Fan Roars on Startup
On my V6, the radiator fan always ROARS on startup. Even if the engine is cool. After a minute or so, it kicks off and the truck is relatively quiet (not as quiet as my tercel). Why does the fan kick on at startup?
Old 09-23-2003, 11:24 AM
scdtrd's Avatar
Dealer : Lagrange Toyota
Last Online: 07-31-2008 05:34 PM
scdtrd is on a distinguished road.
scdtrd's Photo Albums
The fan clutch is locked. It takes a minute or two for it to release.
Mide does the same thing. If you do not like it.... and I do not either.... Go electric. Perm-a-cool and Flex-a-lite BOTH make a very nice product. All I wanna hear when I fire up the 'Yoda is V8.
SCDTRD
The Beast:
1994 Toyota Camry V6 XLE
The Mods:
Front tower Ractive Strut Bar, Whiteline rear AntiSway Bar, Rage Breaker 17.5x7 Rims and Falken Ziex 512 rubber, Limo Tint, Pioneer DEH 7700MP Head Unit, Polk 6x9 rear and Polk 6.5 Front speakers, Tokico struts front and rear, Carbon kevlar brake pads, Cryo treated rotors, ZEX 82021 N2O system, Polished and ported upper and lower intake runners, shift kit, and more to come.....and.... YES... it is a CAMRY....
"Back in the black!"
Old 09-23-2003, 12:42 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 03:11 PM
DevinSixtySeven is a splendid one to behold. DevinSixtySeven is a splendid one to behold.
the startup roar sounds like it's a standard toy thing...yes?
GFX by FreedomEagle50
Manual Hubs
Old 09-23-2003, 12:48 PM
scdtrd's Avatar
Well.. yea.. standard on any clutch fan engine. Any engine that has a clutch fan will do that on a cold start or after it sits for a while off.
SCDTRD
The Beast:
The Mods:
Old 09-23-2003, 05:40 PM
scdtrd knows more about it than me, it must be the clutch thing. My tercel doesnt do it, neither has the prizm, corolla, or other tercel that Ive driven.
Old 09-23-2003, 06:26 PM
Brian M's Avatar
Dealer : Sand Dollar Toyota Scion
2003 Toyota Sequoia
Last Online: 07-17-2008 08:55 PM
Brian M is on a distinguished road.
Send a message via AIM to Brian M Send a message via Yahoo to Brian M Brian M's Photo Albums
Those all have electric fans. No roar.
The Sequoia has it but not nearly as loud as the fan on the '98 Suburban I had. Totally ruined the V-8 sound on that rig.......and in my book nothing sounds better than the 5.7L Vortec.
2003 Sequoia SR5 - Phantom Gray
2006 F150 SuperCrew Lariat - Black/Gold
Old 09-23-2003, 11:50 PM
Dealer : Alamo Toyota
Last Online: 09-16-2008 11:48 AM
Turbo_Tundra is on a distinguished road.
Turbo_Tundra's Photo Albums
I would agree that the clutch is engaged when you start it up, but a minute or 2 for it to disengage seems a little long to me...the "cold" air it sucks into the engine compartment should make it disengage in a few seconds...it may be on its last leg if it doing this for "minutes"...
Old 09-25-2003, 04:15 PM
5 Speed's Avatar
Dealer : Longo Toyota
Last Online: 12-22-2008 09:54 PM
5 Speed is on a distinguished road.
5 Speed's Photo Albums
This is how the fan clutch is on the V-6, it even does it on my friends older Toyota PU with the 3.0 V-6. Someone awhile ago gave an excellent explination of how the fluid moves within the fan clutch when it has been sitting for some time. He explained that it was normal. My Tundra has done this from the very first day and hasn't changed. I will say it is more difficult to sneek out of a campground in the morning when the Dragon Roars at start up You won't notice it is much or for as long if the engine is warm.
Old 09-25-2003, 04:36 PM
From car wizard web site:
"The fan clutch is a small fluid coupling with a thermostatic device that controls a variable-speed fan. The fan clutch ensures that the fan will rotate at just the right speed to keep the engine from overheating, and reduces drive to the fan when it is no longer needed.
The fan clutch has a fluid coupling partly filled with silicone oil designed for just that purpose. If the temperature of the air passing through the radiator rises, the heat alerts a bimetal coil spring to "uncoil" or expand. When it expands, it allows just a little more oil to enter the fluid coupling, so the fluid coupling starts to rotate the fan. If the air coming through the radiator is cool, the opposite happens; the coil spring contracts, the oil leaves the fluid coupling and the fan slows. Slowing the fan when it is not needed reduces fuel consumption, makes less noise and saves engine power.
Sometimes a flat bimetal strip spring is used instead of a coil spring; it bows out and in when the temperature rises and drops, letting oil in and out of the fluid coupling."
Here is another good site on this topic:
http://www.haydenauto.com/f_clutch.html
Old 09-25-2003, 11:54 PM
I tried it again today from cold, it was more like 20-30 secs. Sorry for the misinformation...
Old 09-28-2003, 09:26 AM
Dealer : DCH Freehold Toyota Scion
2006 Toyota Camry-Solara convertable,
2000 Toyota Tundra single cab-V-6 8ft b
Last Online: 12-19-2008 09:20 AM
coal miner is on a distinguished road.
coal miner's Photo Albums
Default Fan Clutch & roaring.
The fan is suppose to roar when you first start it up. Even if it sits a few minutes it will roar on start as the clutch chamber or turbine fills with oil causing it to engage. Once running it takes a minute or 2 for it to empty out unless the bi metal thermo is calling for cooling. But one thing good about it all is you know the clutch fan is working properly. If it doesn't roar something could be wrong. Also, its a big fan on the Tundra so it pushes a lot of air & will make noise & sound like it spinning at 100 miles an hour. Always neighborly, Coal Miner in New Jersey
Bookmarks
