This is a discussion thread titled "Engine Light On", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-26-2003, 11:39 PM
Last Online: 09-04-2006 08:30 PM
OooWeee428 is on a distinguished road.
OooWeee428's Photo Albums
Unhappy Engine Light On
The check engine light on my truck went on while i was driving and i have no idea why. The truck still runs fine and i checked the level on my oil and that's fine too. Any suggestions to why its like this???
Old 09-26-2003, 11:45 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
Last Online: 03-27-2008 09:05 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
Might be an 02 sensor failing. They can go anywhere from 30,000 miles to 60,000 miles, which is about how long they last. Go to autozone and have them read the code to tell you what it might be.
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
Old 09-26-2003, 11:49 PM
Thanks! I have somewhere near 45000 miles on my truck too. By the way if it is my O2 sensor is the truck still safe to drive cause i probably can't get it checked till Monday. Also how much is the cost to replace the sensor.
Old 09-26-2003, 11:54 PM
v8Toilet's Avatar
They cost $$$ at the dealer but you can get them @ www.sparkplugs.com for $50 and they are Denso 02 sensors or what you have now. It’s OK to drive it with the check engine light on.
stock exhaust
TRD LSD
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Old 09-27-2003, 09:25 AM
beemerphile's Avatar
Last Online: 02-14-2006 07:19 AM
beemerphile is on a distinguished road.
beemerphile's Photo Albums
True that it's OK for a little while, but don't let it go too long. If it is one of the primary O2 sensors, the computer will run in "limp home" mode with richer than nomal mixture. If you run this way long enough, you will damage the catalytic converter. THEN you will be spending some serious jack. - Lee
Old 09-27-2003, 10:55 AM
Dealer : Phil Wright Toyota
Last Online: 07-04-2008 02:00 PM
arkie6 is on a distinguished road.
Send a message via Yahoo to arkie6 arkie6's Photo Albums
Almost every check engine light issue relating to O2 sensors posted on this site to date has been due to a malfunction of the O2 heater circuit, not the O2 sensor itself. A malfunctioning O2 heater circuit will not force the ECU to go into open loop mode under normal driving conditions because the O2 sensor is still functional when hot. The only problem I can see from this condition is that it may take a little longer for the O2 sensor to heat up which will delay the ECU from going from open loop mode (ignores O2 sensors) when first started to closed loop mode when in normal operation (lowest emissions).
My truck has been operating just fine for close to 6 months with a check engine light as a result of a O2 sensor heater circuit failure. I have noted no change in performance or fuel economy and I check the MPG on every fill up.
I do agree that it is still a good idea to get the check engine light investigated to find out what is causing the light. If it is just the O2 sensor heater circuit failure, then no harm is being done to the engine or catalytic converters in my opinion.
Old 09-27-2003, 10:00 PM
thanks guys i'm not freaking out as long as i was anymore. But i will for sure get it checked on monday
Old 09-28-2003, 09:32 PM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4
Last Online: Yesterday 08:19 PM
LGL002 is on a distinguished road.
LGL002's Photo Albums
I thought California emission rules required a longer factory warranty on o2 sensors sold in the State. Shouldn't make any difference if you aren't the original owner
2004 Tundra V8 Limited Access Cab 4X4, Michelin 265/65/R17 ATX2 tires, Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
Old 09-28-2003, 10:18 PM
OK! Now i'm confused cause my dad was driving the truck yesterday to see if there was anything wrong with it then suddenly the check engine light went off. What am i supposed to think now???
Old 09-28-2003, 10:47 PM
v8Toilet's Avatar
If you don’t tighten the gas cap all the way until it clicks you could get a mill light because the evaporative emissions systems won’t hold pressure.
stock exhaust
TRD LSD
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Old 09-28-2003, 10:50 PM
So do you think that it was just my gas cap cause my dad did just fill up my tank yesterday.
Old 10-12-2003, 01:31 AM
ske ske is offline
Last Online: 05-11-2008 11:03 PM
ske is on a distinguished road.
ske's Photo Albums
Default dissapearing check engine light
I was just as confused when the same thing happened to me the other day. When I got home I cracked open the repair manuals and found out there are a couple of fail safe systems in place.
First, you will not get a (MIL) malfunction indicator lamp or "check engine light" for a malfunctioning emision control system unless the computer detects this for 2 trips. Meaning the malfunction has to occur twice with the ignition being shut off between them.
Second, If you continue driving the vehicle and the computer does not detect the malfunction for 3 consecutive trips the MIL will go out.
This happened to me and now the light is back on which sounds to me like its a sporadic failure. I had the code checked at a local shop today - P0155 "Oxygen sensor heater circuit malfunction". Im going to check with the dealer on Monday to see if its covered under the emision control warranty since im at 43k. If not I'll replace it myself. Hope this helps.
Old 11-30-2003, 09:03 PM
Dealer : Doenges Toyota
2004 Toyota Camry LE Blue
Last Online: 12-30-2007 05:02 PM
evad3257 is on a distinguished road.
evad3257's Photo Albums
Default heater circuit
hey arkie6,
I am confused. Are you saying that the heater circuit is a different part than the o2 sensor, or are they combined. I understand driving without the heater circuit working properly won't hurt, but will replacing the sensor cure the heater circuit, and therefore, the MIL?
Thanks.....
Old 12-01-2003, 10:47 AM
JeffD's Avatar
Last Online: 04-23-2007 11:02 AM
JeffD is on a distinguished road.
JeffD's Photo Albums
The heater circuit is built into the o2 sensor and can't be replaced seperately. I don't know if it detects the fault by seeing an open circuit, or if it sees that it takes too long before it gets a good signal from the O2 sensor.
2000 4x4 LTD AC Sunfire Red - Sold w/ 200K
2005 4x4 LTD AC Phantom grey w/ dark grey - Sold w/ 20K
Alpine CDA-9835, W/ KCA-420i, Focal 165KP front, Focal 165V Rear speakers. powered by 2 MMats SQ2150 amps. Alpine MRD-M501 powering a JL Stealthbox with Infinity Perfect 10D VQ
Sound deadened everything with Cascade VB2HD, and Dynamat Extreme
2005 G35 Sedan 6MT - Returned due to paint work on a 'new' car.
2006 G35 Sedan 6MT - all stock. Where do I hook up the trailer and where's the bass?
Old 12-01-2003, 01:05 PM
Originally Posted by evad3257
hey arkie6,
Thanks.....
What Jeff said above. The oxygen sensor and oxygen heater circuit are electrically separate, but physically integrated into a single device. That is why our O2 sensors have 4 wires - 2 for the O2 sensor and 2 for the heater circuit. Can't replace one without the other.
Bookmarks
